Tyre Pressures?
2FST4U
Around 20psi is the norm. Anywhere from 10-50psi will be fine depending on your setup, style and what sort of stuff you ride. I personally recomend between 20-30psi!
The best way to find the best pressure for you is to try loads of different pressures until you find something you like.
Ok i'll start with 20psi and see how it goes, cheers
