Sprockets
Fvil
Hey everyone
I need some one to tell me some information on sprockets.
basically what would happen if i change it the amount of teeth on the sprocket?
at the moment i m running tensile front freewheel, and 12teeth monty sprocket.
advice pleease :lol:
thankyous
A bigger front sprocket will give a higher gear, a bigger rear sprocket gives a lower gear.
If you don't get gear ratios try thinking about them in terms of how much chain the sprocket moves, so a 18T front sprocket in one turn of the cranks moves the chain forward 18 rollers. If the rear is a 12T then this sprocket has to be driven on 18 roller's worth of chain too.
12 rollers of chain moved will cause a complete turn of a 12T sprocket, so it makes sense that the gear ratio is 18/12 = 1.5, this means the rear wheel turns 1.5 times for each turn of the pedals. If you want a higher gear change to a smaller sprocket at the back, if lower use a bigger rear sprocket.
