Hope Mono Trials
Luke_zoo
As the above says ^
my wheel will no spin no more, the brakes just not wanting to move (N) not sure wats up with it, it's a pain like.
any ideas on how to get it to move agen?
First, write your topics in clear english.
I'm not quite sure what you mean.
Are the pads constantly against the disk?
Is the calliper rubbing the disk?
Does the wheel move slightly or not at all?
How old is the brake?
When was it last bled?
Is the disk rotor bent?
Could be any number of things with what you posted.
Disc is fine, has been bled not long ago but hasnt worked since the local shop bled it (N) Pads are fine. no rubbing just wont move so i have no idea what the shop have done.
If the pads aren't rubbing the disk then the wheel should spin freely.
Is the disk rotor rubbing the calliper?
If not it may be something wrong with your hub.
HUbs fine it spins with out it on the bike, just when the brakes on theres nothing there but if I hit the wheel into somthing it moves for so long untill i press the brake and it stops agen. I think i should go back to the shop who bled it as it hasnt been right since then
What sorry that post made no sense?
Doesn't look like its the hub then.
What do you mean by this? "if I hit the wheel into somthing it moves for so long untill i press the brake and it stops agen "
Right, when i hit the wheel with somting it moves agen but after using the brake it stops moving as if the pads wont move but they have, maybe i have air blocked in it?
Edited by :)zoo!
The calliper sounds sluggish, this means when you press the lever the pads come out as normal, but when you release the lever they take a while to go pack into the calliper.
Sounds like it either needs new seals, a good bleed or a service from someone who knows what there doing.
Hope this helps.
Davey.
Hope this helps.
Davey.
will get brake sent off soon to some where like tarty or somthing, but it sounds about right (Y)
