Noob Crank Qusetion
16 years later
Right im running my cranks with a bash ring that the chain ring bolts on to, I've always had this style. So my question is if i get new cranks, with a bash ring that does not have a chain ring that you bolt to it. Would i just get the cranks, slide the bashring on and then put a screw on sprocket on. Is it the screw on sprocket that holds the bashring in place, or something else? Sorry for the noob question and I hope you can understand what im on about.
Thanks Bruce.
