scott21 Posted January 18, 2009 Report Share Posted January 18, 2009 Hi there can i use a stone disk with diamonds on the edge to grind my wheel or does it have to be a metal disk.many thanks Quote Link to comment Share on other sites More sharing options...
MiuSliS Posted January 18, 2009 Report Share Posted January 18, 2009 If you want a sharp grind use metal disk. I used stone disk once, the grind came out mid or maybe even light. Quote Link to comment Share on other sites More sharing options...
Cresswell_d Posted January 18, 2009 Report Share Posted January 18, 2009 Yeah you can 'cos I use one and it give a light grind. But after a while it kills the disk though! (but you can still use it)Daz. Quote Link to comment Share on other sites More sharing options...
scott21 Posted January 18, 2009 Author Report Share Posted January 18, 2009 So which is the best grind so i can use cousts which need to be bed in. Quote Link to comment Share on other sites More sharing options...
chris slater Posted January 18, 2009 Report Share Posted January 18, 2009 So which is the best grind so i can use cousts which need to be bed in. you cant beat a sharp grind! pads may wear abit faster but so what, its braking power we all need my friend! metal!!!! Quote Link to comment Share on other sites More sharing options...
scott21 Posted January 18, 2009 Author Report Share Posted January 18, 2009 you cant beat a sharp grind! pads may wear abit faster but so what, its braking power we all need my friend! metal!!!! Cheers for the help im going to use metal disk,First time doing it hope it goes well. Quote Link to comment Share on other sites More sharing options...
