Grind A Disc?
Jamie_Trials
wouldnt advise it
are you crazy,grind on disk :sick::sick::sick:
If you have a good setup then you wouldn't have to be so stupid!
i havent built the whole bike yet i was just wondering before i put it on
so no :)
It will not work, the whole idea of a disc brake is to have 2 smooth surfaces that cause high amounts of friction, causing the stopping power.....
Adam
oh right cheers
i thought it might be abit like rims :unsure:
A friend of mine sandblasted his disk to roughen it. Made the bite a little better for a few hours, then the pads polished it back to normal. Don't think overall power was improved at all though. Disks with bigger holes tend to have more bite and hold thanks to them allowing the brake pads to flex into the holes more when the brake is pulled if you're unhappy with the brake you have.
Tried it with an half crappy disk and will never do it again. It got so bad that a V-brake with rubber bands instead of wire would have been better.
I grinded it with a angle grinder, and then I took a beltsander and got it smooth again and then I got some brake power back but it was wobbly and still crap.
If you get something like oil, wax or something like that on the disk then burn it. And then use brake cleaner. Don't try to sand or polish it.
I don't know how the larger holes affects the braking power but I think no holes at all and a smooth contact surface is the best for trials. Large holes are for cooling because a hot disk = less braking power. In trials you only use the brake for short and hard braking. But like downhill you brake for a long time and build up the heat and need more cooling so there you need more holes and even doubble walled disks with inside ventilation.
I'm not a brake tech specialist but that's what I think based on my own experience.
...If you get something like oil, wax or something like that on the disk then burn it. And then use brake cleaner. Don't try to sand or polish it...
or wipe it with napkin or rag,or clean it with some kind of alcohol ;)
Forgot to mention about the pads. The disk may be easy just to wipe of but the pads isn't. You may have to run down a long slope with the brake hold in to get it up to heat and wear it off.
But with heat you get full grip instantly afterwards. They don't have to glow, about 300°C is enough and stove works fine.
