Stretching Chris King Springs.
Ashley-Wood
-Remove the Collar off the axle.
-Remove the Freehub body.
-You then need the Chris King service tool in order to get the internals out or if you wanna risk it, you can use a hammer and screwdriver.
-Remove the internals, Clean all the grease and crap off everything.
-Take the spring, stretch it as long as you want.
-Put it all back together.
-Your king now sounds like a heard of bumblebees :)
-Hannah,x
P.s - I think tarty Adam put a video on youtube/vimeo on how to take a King CLASSIC apart, but i THINK the internals are the same.
The Chris king noise is a novelty that wears off very quickly, and soon becomes annoying as hell, and you will be packing it back full of grease just to shut it up in no time.
Like a lot of people have said, is it really worth the risk of potentially wrecking a perfectly good hub because it doesnt sound as loud as Mr X's? Just attatch a playing card to your chainstay if you are really that fussed about the noise...
Get a king service from tarty, stretching the springs only makes the hub skip more.
No..
Please can anyone explain how it'll make it skip more?!?!
It's pushing the two drive rings together harder and stopping them from skipping.
My king used to skip all the time.
Now it doesn't, guess what I did..
When it's re-compressed to the original length the diameter increases, making it stick on the inside of the hub shell - thus producing less force.
