Pad Help Please.
Sticky!
I have noticed there arent many pads around atm, but with previous experience im no good. i pick em and they dont bite.
I want pads for my front wheel. brake mounted behind the forks.
i like gapping to front so they need to bite well. i dont mind weather its smooth or grind as its a new rim so i can do whatever. any reccomendations ?
There are loads of pads around compard to about 2 years ago.
Also my Koxx blues work really well on a smooth rim, but most others say theres were horrible.
i'v just gone back to koxx browns after a good 4 years or so...and they're still f**king super (Y)
Same here, had standard Koxx browns on the Czar and they were really good, then got the Brown Crocos on the Yaabaa and they are awesome too.
Crocos appear to have a little more bite and noise at the detriment of a small amount of hold, but not really noticeable.
Might have to try some heatsink pads myself. I still struggle to get decent braking performance. I have just ground a new tryall rim with a metal cutting disc at a 90 degree angle (as I think you are supposed to), with either plazzies (yellow) or blue rock pads it seems shite. Drives me mad.... I land the back wheel on an edge, rather than hold the brake goes 'whoosh' and I slip of the obsticle feeling annoyed to be let down!
