Disk Brake Help!
pudding
I don't have disk brakes, but would'nt some white spirits clean them? Just like you clean tar off your rim that 'should' work. :unsure:
After you've got all the dirt and stuff off just give them a quick wipe with a damp rag and let them dry.
Edited by dave!
White spirit is basically a pure alcohol cleaner and I am pretty sure it does not have an oil base like paint thinner (correct me if I am wrong). Because of this it will be fine, I personally use cheap nail varnish remover and it works well.
White spirit is oil based!!!
Note how it smells like WD40 and spray oils.
clean the rotor in water a washing up liquid for as long as you can.
nail varnish remover will probably work :).
My mate already said, i simply use sandpaper for the pads and rotor and apply some pressure when doing it to give the rotor and unsmooth surface, this will ensure it's clean.
Once re-fitted all clean use the brake just on your front for a few mins to make sure it's biting again. it works for me and one of my pads was really bad on the rear!
there's also baking the pads but MEH i have never tried and dont intend to.
james.
