Luke_zoo Posted January 6, 2009 Report Share Posted January 6, 2009 I know this is trials forum, and I know you will say go to a motorbike forum, but i'm busy at the mo, so thought I will ask if anyone has had the bikes or still has them?right, the problems, clinder head might of blown?theres a spark, just no compression the coils are fine, it used to run just isnt working no more so I cannot have my fun anymore If anyone knows please helpCheers,Luke Quote Link to comment Share on other sites More sharing options...
Fishy Posted January 6, 2009 Report Share Posted January 6, 2009 Suzuki 80? Quote Link to comment Share on other sites More sharing options...
tris Posted January 6, 2009 Report Share Posted January 6, 2009 So the engine is turning over and it has a spark. But it has little or no compression.I take it it's a 2 stroke???Take out the plug and put you finger onto the hole and kick the bike over hard. How much compression is there?? Does it push your finger off the hole??If there's low compression then it will probably need to have a new piston and ring or it may need re-boring.Head gasket could be gone but i doubt it.....Also if it has low compression is won't normally start off the kickstart. Try bump starting it down a hill and into 2nd gear because that should get it going (it should run on low compression just might not tick over and won't be too powerful).Clean the plug too.Hope this helps. Quote Link to comment Share on other sites More sharing options...
Luke_zoo Posted January 6, 2009 Author Report Share Posted January 6, 2009 (edited) So the engine is turning over and it has a spark. But it has little or no compression.I take it it's a 2 stroke???Take out the plug and put you finger onto the hole and kick the bike over hard. How much compression is there?? Does it push your finger off the hole??If there's low compression then it will probably need to have a new piston and ring or it may need re-boring.Head gasket could be gone but i doubt it.....Also if it has low compression is won't normally start off the kickstart. Try bump starting it down a hill and into 2nd gear because that should get it going (it should run on low compression just might not tick over and won't be too powerful).Clean the plug too.Hope this helps.4 stroke edit: going to strip bike down to morrow day time. Edited January 6, 2009 by :)zoo! Quote Link to comment Share on other sites More sharing options...
Luke_zoo Posted January 6, 2009 Author Report Share Posted January 6, 2009 Will there be a blocked pipe? Quote Link to comment Share on other sites More sharing options...
CZARKID Posted January 6, 2009 Report Share Posted January 6, 2009 If your a member on the trials central it could be a good idea to put the topic on there as well. I put all my motorbike problems (and trust me there's loads) and i normally get a good helpful reply within a day.cheers alexp.s. No dis-respect to the people on this forum by saying you will probably get a better answer on trials central. But it is a motorbike trials forum. Quote Link to comment Share on other sites More sharing options...
davey1991 Posted January 6, 2009 Report Share Posted January 6, 2009 If your a member on the trials central it could be a good idea to put the topic on there as well. I put all my motorbike problems (and trust me there's loads) and i normally get a good helpful reply within a day.cheers alexp.s. No dis-respect to the people on this forum by saying you will probably get a better answer on trials central. But it is a motorbike trials forum.Yer moto trials people will know more.Now be gone motorcyclist .Nahh hope you solve your problems quickly. Quote Link to comment Share on other sites More sharing options...
Luke_zoo Posted January 7, 2009 Author Report Share Posted January 7, 2009 Yer moto trials people will know more.Now be gone motorcyclist .Nahh hope you solve your problems quickly.Piston rings are dead ha ha should work when new stuff comes Quote Link to comment Share on other sites More sharing options...
Luke_zoo Posted January 7, 2009 Author Report Share Posted January 7, 2009 Problem solved lads! Quote Link to comment Share on other sites More sharing options...
r2wtrials Posted January 7, 2009 Report Share Posted January 7, 2009 wasn't aware that Suzuki ever did an 80 trials bike?When you put the rings back in smear a small amount of engine oil on the bore before you assemble... just helps everything start up with a bit of lube place. Don't go wild or you will smoke a bit Quote Link to comment Share on other sites More sharing options...
Luke_zoo Posted January 9, 2009 Author Report Share Posted January 9, 2009 wasn't aware that Suzuki ever did an 80 trials bike?When you put the rings back in smear a small amount of engine oil on the bore before you assemble... just helps everything start up with a bit of lube place. Don't go wild or you will smoke a bit all been sorted ha ha ,cyclinder head was gone, needs skiining and that Quote Link to comment Share on other sites More sharing options...
