leotrialp Posted January 5, 2009 Report Share Posted January 5, 2009 (edited) Hello, i´m Leonardo, from Argentina , and my bike is too heavy, it weights like 14kg (14000grs), and the last time than i build it, i felt it heavier (and its heavier ). Even so, i love it...but...is a home made frame of steel, and it weights 2.6kg(2600grs) aproximatly, so it´s heavy haha...my front rim full built up weights 2.3kg (2300grs), so it isn´t light, and my fork is of CRO-MO 4130, and weights 1.4kg(1400grs)...my rear rim is a vzan v trial, with a intense DH 2.35 (2.44 realy), my cranks are a shimano alivio 98" (heavyer but stronger), with one pair of diamondback pedals, a modified and reinforcered hub and with bearings too with a 18 bmx sprocket modified, and my stem and handlebar are ZOOM 31.8(works very well)... so....what can i do to it???i want to drill it but i don´t want to lose too much resistance...and i want to do it because i have 2 months to work in it because i broke my fot (like you can see in the pictures below )...i broke a bone below of a finger, and the thumb finger in 2 parts, but isn´t appreciate...I have 3 nails now , they lined the bone, and they put the nails, like in the pic below... thanks for read this topic and sorry about my english Edited January 5, 2009 by leotrialp Quote Link to comment Share on other sites More sharing options...
leotrialp Posted January 5, 2009 Author Report Share Posted January 5, 2009 and i want to do it because i have 2 months to work in it because i broke my fot (like you can see in the pictures below )...i broke a bone below of a finger, and the thumb finger in 2 parts, but isn´t appreciate... i broke my FOOT riding Quote Link to comment Share on other sites More sharing options...
Muel Posted January 5, 2009 Report Share Posted January 5, 2009 First I'd change the forks for some Echo Control or SL forks, that would loose you 550g.Then I'd get a lighter front wheel, I think mine is about 1700-1800g from memory, so that's another 600g.The next heaviest thing is probably the frame and rear wheel. Quote Link to comment Share on other sites More sharing options...
Lewis-Trials Posted January 5, 2009 Report Share Posted January 5, 2009 Nice bike mate, I sugest you get the drill out and drill the rear wheel, And other place's where its unlikely to crack easier. Quote Link to comment Share on other sites More sharing options...
Jordan GU Posted January 5, 2009 Report Share Posted January 5, 2009 Nice bike mate, I sugest you get the drill out and drill the rear wheel, And other place's where its unlikely to crack easier.Seems good to me lol. Quote Link to comment Share on other sites More sharing options...
Muel Posted January 5, 2009 Report Share Posted January 5, 2009 I managed to save 60g by drilling 7mm holes in my front rim, and the gaps between the holes are like 5mm.He wants to loose a lot of weight fast, when your bike weighs 14kg, even loosing half a kilo won't make much difference. Quote Link to comment Share on other sites More sharing options...
leotrialp Posted January 5, 2009 Author Report Share Posted January 5, 2009 First I'd change the forks for some Echo Control or SL forks, that would loose you 550g.Then I'd get a lighter front wheel, I think mine is about 1700-1800g from memory, so that's another 600g.The next heaviest thing is probably the frame and rear wheel. yes , but in here we can´t buy any echo product , so thas the deal.... Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted January 5, 2009 Report Share Posted January 5, 2009 Tartybikes offer a worldwide postage option. Quote Link to comment Share on other sites More sharing options...
RETROLEO Posted January 6, 2009 Report Share Posted January 6, 2009 (edited) Looks a very nice frame, but if its homemade then guess you wont want to be swapping that? That might be your problem! You could drill the frame to loose some of the wight instead of getting a new one. E.g. down the top tube and bottom tube.Also cut some noble's of your tires although this does not loose much. Hope you take some of this into consideration, and use the tips found help full. Leo. Edited January 6, 2009 by RETROLEO Quote Link to comment Share on other sites More sharing options...
Connor Powell Posted January 6, 2009 Report Share Posted January 6, 2009 Just order from tartybikes, theyl post it to you. Quote Link to comment Share on other sites More sharing options...
leotrialp Posted January 6, 2009 Author Report Share Posted January 6, 2009 (edited) Nice bike mate, I sugest you get the drill out and drill the rear wheel, And other place's where its unlikely to crack easier.ok, thanks for the help Looks a very nice frame, but if its homemade then guess you wont want to be swapping that? That might be your problem! You could drill the frame to loose some of the wight instead of getting a new one. E.g. down the top tube and bottom tube.Also cut some noble's of your tires although this does not loose much. Hope you take some of this into consideration, and use the tips found help full. Leo.TXS for the tips ....Just order from tartybikes, theyl post it to you.my problem is the money than it cost to me, because in here, a frame cost a lot, and the "post" too, so isn´t cheap, that´s why I want to drill it ... Edited January 6, 2009 by leotrialp Quote Link to comment Share on other sites More sharing options...
maxxis26 Posted January 6, 2009 Report Share Posted January 6, 2009 (edited) check the for sale area im sure if you ask nicely most will post overseas for you, postage will be more but you will get some cheap parts out of it you can find everything you would need to shed some serious weight and fast also consider some of the cheaper brands out there saracen and onza for starters?love the look of that frame just a shame its so heavy if you can make something like that homemade could you not make a similar frame from aluminium? Edited January 6, 2009 by maxxis26 Quote Link to comment Share on other sites More sharing options...
leotrialp Posted January 7, 2009 Author Report Share Posted January 7, 2009 check the for sale area im sure if you ask nicely most will post overseas for you, postage will be more but you will get some cheap parts out of it you can find everything you would need to shed some serious weight and fast also consider some of the cheaper brands out there saracen and onza for starters?love the look of that frame just a shame its so heavy if you can make something like that homemade could you not make a similar frame from aluminium?yes, I can do a light frame from aluminium, but it cost to me like £200..in here is a lot, thinking than my bike cost like £300 hehe, and will not be the same quality as a good frame...for that price, I pay a litle diference, and I can buy a good frame, like the frames of "DENG" or other of the "BIG MARKS"...for the moment I want to drill it, I will change the fork by a aluminium fork, and the front tyre, it saves to me 1kg later I´m going to cut a litle the dropouts, and drill the frame in the head tube, the bb , the vertical tube, a litle more the front wheel, and the hubs too ...I hope to reach 12.5kg or less ...bye and thanks Quote Link to comment Share on other sites More sharing options...
