trialsmax04 Posted December 30, 2008 Report Share Posted December 30, 2008 i know it has been coverd in the Wiki section on here, but im going to need some advice for bleeding my hs33's. The thing is, i would like to do it with oil. I have the syringe and pipe etc but no barbed fittings. The technique on the wiki requires at least one of these, but i have none spare. Is there another technique i could use?many thanks max Quote Link to comment Share on other sites More sharing options...
bigamac Posted December 30, 2008 Report Share Posted December 30, 2008 (edited) Try bleeding with water. Much better feel in my opinion.Then you can bucket bleed which takes all of 5 mins.And instead of posting two topics you should of posted both in one. Edited December 30, 2008 by bigamac Quote Link to comment Share on other sites More sharing options...
Danny Metcalfe Posted December 30, 2008 Report Share Posted December 30, 2008 If your HS33 is bleeding, you'd best put a plaster on it.hope I've helped mate Quote Link to comment Share on other sites More sharing options...
trialsmax04 Posted December 30, 2008 Author Report Share Posted December 30, 2008 yea fair enugh, should have posted it there and put a plaster on the brake. lol. Im not to sure with using water because of freezing problems :$ tis buggery cold down here at the moment! Quote Link to comment Share on other sites More sharing options...
bigamac Posted December 30, 2008 Report Share Posted December 30, 2008 yea fair enugh, should have posted it there and put a plaster on the brake. lol. Im not to sure with using water because of freezing problems :$ tis buggery cold down here at the moment!I dont do it, but been told to.Put anti freeze in the water.Only a small about though. Quote Link to comment Share on other sites More sharing options...
Andrew Willis Posted December 30, 2008 Report Share Posted December 30, 2008 Anti-freeze and water does work but pure theres always the change you could wreck the pistons.use water;more effectivetakes 5 minseasy to doAndy Quote Link to comment Share on other sites More sharing options...
G-baby158 Posted December 30, 2008 Report Share Posted December 30, 2008 Anti-freeze and water does work but pure theres always the change you could wreck the pistons.use water;more effectivetakes 5 minseasy to doAndy5 mins more like 1, if that. Quote Link to comment Share on other sites More sharing options...
Ryan-Trials Posted December 30, 2008 Report Share Posted December 30, 2008 +1 for water bleed Quote Link to comment Share on other sites More sharing options...
