Hope Mono Mini Brake
Jamie_Trials
if its a standard hope mono mini ( gold bore cap )....it wont be great for trials....mine with a 180 rotor on the front of a stock was pretty kak to be honest; and as you say your framew told you so; i assume you're gonna go rear disc,.....id go for a bb7 or a mono trial to be honest mate....
or do it properly and run a a magura :)
  • 2 weeks later...
I'm about to go to rear disk, iv got a hope mono 160mm on the front and its brilliant, and iv never had any problems with it. Personally go for a rear hope mono and it wont let you down. Although there expensive they are worth it.
I have a mono mini on the front with a hope trials 160mm rotor. Needs a bit more bedding in but at the moment it's still great. Although the rotor is about 5mm wider than the mono mini pads it still works great.
I went over my bars and almost faceplanted once, that was just going up a curb and slammed the front on forgetting how quickly it bites.
But I don't think a mini on the back will be any good. Proper hope trials on back and mono mini more suitable on front.
