Fixing Threads
Jack Chinnery
you cant. Basically.
From your poor english, I have no idea what the problem exactly is, but there are only a couple of ways out of a raped thread:
Helicoil is (use the search)
Drill straight through and use a nut on the other side
Chemical metal
Note chemical metal isn't particularly strong enough for something like brake mounts. If its the thread on a brake lever though it may be good enough. But if you want an answer, try telling the forum which threads it is that you've knackered. Depending on what it is, it may be cheaper to buy a new part
Chemical metal
Sorry about the bad spelling, But ive been rushing around because im going on the reading ride tmrw and would regret not going on it :(. But yes, The tpa on an 05+ lever. The red twisty thing is threaded and want to temporarily fix it :).
Yeah in this case then cleaning the threads out with a tap is easiest option, not always guaranteed to work though. If you cant get hold of the right sized tap, don't bother going out and buying one, when buying a new tpa or buying an upgrade will be cheaper (Y)
