Ozonys Xs26
T.McMillan
Spec is as follows:
Ozonys XS26
TrialTech forks, in silver
Tryall rear pink rim
Tryall front pink rim
Hope pro 2 trials rear n.r.b prototype hub in green with ti bolts
Hope pro 2 front hub and skewer in green
Trialtech Stem
Monty Ti riser 07, in silver
Fsa Headset
TrialTech heavy duty BB
TryAll cranks
TrialTech Bash
Wellgo Mag Pedals
NC-17 Green crank bolts
Magura HS33 Rear
Hope TartyTrial Front
Prototype chain tensioner
TrialTech Grips
TrialTech front and rear sprockets
TrialTech carbon single speed spacer kit
Kmc Kool 710 chain
Maxxis Hansventure rear tyre
Maxxis Ignitor front tyre
A great thanks to Owen at Hope for sorting me out with parts, Alex at Rolling Resistance and TartyBikes for everything else.
Might make a couple more subtle changes but its pretty much how I like it, tell us what you think
Regards
Tom
p.s. I might add some better quality pictures soon that will pick out the colours more, its abit grainy and dull at the moment
Edited by T.McMillan
Spec is as follows:
Ozonys XS26
Trialtech Stem
Fsa Headset
TryAll cranks
TrialTech Bash
Wellgo Mag Pedals
Magura HS33 Rear
TrialTech Grips
Kmc Kool 710 chain
Regards
Tom
wtf's that? :blink:
bikes amazing (Y)
Needle Roller Bearing, can withstand alot stronger force than normal ball bearing races
Hopefully they make it so that:
The ratchet ring doesn't strip.
The bearings don't crush every 5 minutes.
The hubshell doesn't crack.
Then it'll be AMAZING.
I like your bike, check for cracks on the driveside dropout!
why's that are they known to crack there?
