Mtchell Posted December 21, 2008 Report Share Posted December 21, 2008 (edited) Just got new Czar 20 with Echo SL forks I have had a FSA PIG headset fitted! by a bike shop , I went for a ride today and found the forks move back and forth slightly when the front brake is applied.The headset can,t be worn becase it was brand fire new from tarty, Ive tighten the top cap as tight a possible.I have the star nut left over front the headset because the shop said i didn't need it as theres 1 in the forks which is true enough.I don,t want to take the bike back is there any thing i could do to correct it ??? Any help would be highly appreicated. Edited December 21, 2008 by Mtchell Quote Link to comment Share on other sites More sharing options...
MikeCottTrials Posted December 21, 2008 Report Share Posted December 21, 2008 I think you'll find (so long as the bearings etc are all placed in the correct order) that its just not tight enoughTry unscrewing the bolt a little and banging it down so the star nut goes in further, then give it another tighten also make sure you front wheel is in tight, obviously ive never made the mistake of having a loose front wheel and thinking its the headset Quote Link to comment Share on other sites More sharing options...
Mtchell Posted December 21, 2008 Author Report Share Posted December 21, 2008 Are you talking about the star nut which the top cap bolt attaches to? If so its welded to the inside of the forks mate i think.Wheels tight . Quote Link to comment Share on other sites More sharing options...
N.Wood Posted December 21, 2008 Report Share Posted December 21, 2008 Did you undo the stem bolts before you tightened the top cap bolt? Quote Link to comment Share on other sites More sharing options...
Mtchell Posted December 21, 2008 Author Report Share Posted December 21, 2008 Did you undo the stem bolts before you tightened the top cap bolt?Lol yep . What if i used a long bolt to it pull down harder or do you think this will damage the star nut ??Sorry for the Noob questions lol Quote Link to comment Share on other sites More sharing options...
16 years later Posted December 21, 2008 Report Share Posted December 21, 2008 I’d say try another stem stacker, is your stem above the level of the top of the steerer tube? You may not be getting enough tension, I’d say chuck another stacker on. See if the works out. You can put it on top of the stem or the bottom. Quote Link to comment Share on other sites More sharing options...
Mtchell Posted December 21, 2008 Author Report Share Posted December 21, 2008 If it helps i can see the movements on the top crown, is it??, which the spacers sit on top .I’d say try another stem stacker, is your stem above the level of the top of the steerer tube? You may not be getting enough tension, I’d say chuck another stacker on. See if the works out. You can put it on top of the stem or the bottom.Nope slightly below the fork stem top This maybe my problem Quote Link to comment Share on other sites More sharing options...
PaRtZ Posted December 21, 2008 Report Share Posted December 21, 2008 If it helps i can see the movements on the top crown, is it??, which the spacers sit on top .Nope slightly below the fork stem top This maybe my problem I think so.If this is right, and you can see fork steerer poking out ABOVE your stem, then when you're clamping the top cap down, all your doing is squashing the steerer and not clamping anything. You can solve it by as said stacking it up more underneath, or trimming the steerer about 5mm. Bare in mind don't cut it too much so theres nothing for the stem to clamp onto, but you need to take enough off so that its well below the top of the stem. Take into account the thickness of the topcap itself too! Quote Link to comment Share on other sites More sharing options...
Mtchell Posted December 21, 2008 Author Report Share Posted December 21, 2008 I think so.If this is right, and you can see fork steerer poking out ABOVE your stem, then when you're clamping the top cap down, all your doing is squashing the steerer and not clamping anything. You can solve it by as said stacking it up ...........Cheers mate and everyone else, just a simply mistake i've made and not relised i think lol, Going to try the stackers first before going at it with a hack saw .And thanks againI'll let you know if this doesn't work Quote Link to comment Share on other sites More sharing options...
TrialsGilly Posted December 21, 2008 Report Share Posted December 21, 2008 Cheers mate and everyone else, just a simply mistake i've made and not relised i think lol, Going to try the stackers first before going at it with a hack saw .And thanks againI'll let you know if this doesn't workHello man, got as FSA for myself aswell , and took me around 10 mins alot of tighening , and some front wheels before my Pig was well and truley in!In regards to your problems, i would advise using spacers to solve it rather than hacking away at your forks, then you can get it exaclty right, and your forks will be fine it you come to buy a new bike!Regards Tom Quote Link to comment Share on other sites More sharing options...
weirdoku Posted December 22, 2008 Report Share Posted December 22, 2008 Are you missing one of these headset wedge? The forks shouldn't move at all if theres a wedge on the top and bottom of the headset. Quote Link to comment Share on other sites More sharing options...
RossMcd Posted December 22, 2008 Report Share Posted December 22, 2008 It might be possible that the fork steerer is touching the stem cap, making it not tighten any more. try adding a stacker of cutting your fork steerer slightly (remebering to knock down the star nut too) Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted December 22, 2008 Report Share Posted December 22, 2008 Most likely to be your brake pads wobbling.To see if the headset is tight, turn the front of the bike round 90degrees, and try it then. If it wobbles, then the headset is loose, if not, it's your brake pads wobbling.Nothing to worry about really, most disc brake pads have slight play in them. Quote Link to comment Share on other sites More sharing options...
grant_hundley Posted December 22, 2008 Report Share Posted December 22, 2008 Most likely to be your brake pads wobbling.To see if the headset is tight, turn the front of the bike round 90degrees, and try it then. If it wobbles, then the headset is loose, if not, it's your brake pads wobbling.Nothing to worry about really, most disc brake pads have slight play in them.If it helps i can see the movements on the top crown, is it??, which the spacers sit on top . Quote Link to comment Share on other sites More sharing options...
Mtchell Posted December 22, 2008 Author Report Share Posted December 22, 2008 Are you missing one of these headset wedge? The forks shouldn't move at all if theres a wedge on the top and bottom of the headset.No got that piece mate Most likely to be your brake pads wobbling.To see if the head........I,ll bare that in mind mate but ican see the movement in the top crown .cheers though Quote Link to comment Share on other sites More sharing options...
Sidehop Stuart Posted December 22, 2008 Report Share Posted December 22, 2008 Mine did this. I realised my forks didn't have a crown race and now they don't wobble. Quote Link to comment Share on other sites More sharing options...
Mtchell Posted December 22, 2008 Author Report Share Posted December 22, 2008 Sussed it Another spacer and a slightly longer bolt and its sturdy as houses now Well chuffedCheers everyone Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted December 22, 2008 Report Share Posted December 22, 2008 I,ll bare that in mind mate but ican see the movement in the top crown .Alright, alright! I was tired...I missed out certain posts...leave me alone. Quote Link to comment Share on other sites More sharing options...
Mtchell Posted December 22, 2008 Author Report Share Posted December 22, 2008 Alright, alright! I was tired...I missed out certain posts...leave me alone. Its cool mate, nice bit of info for me to know like, Quote Link to comment Share on other sites More sharing options...
