cox. Posted December 20, 2008 Report Share Posted December 20, 2008 Hey there, My iPod Touch cannot connect to the internet even though i have full signal strength. it's really irritating cause i would like to use my iPod Touch's internet. I have a wireless connection at home, and it doesnt load any pages, the iPod touch only says can not connect to internet, but it has full signal strength! Please help. cox x Quote Link to comment Share on other sites More sharing options...
Tomm Posted December 20, 2008 Report Share Posted December 20, 2008 Is your router working? If the router isn't connecting to the internet properly, you'll get full wifi signal but no internet.Then try the obvious stuff - restarting the router/modem/ipod. Have you ever used the iPod for the internet at home? Is the WEP/WPA or whatever set up properly? Quote Link to comment Share on other sites More sharing options...
cox. Posted December 20, 2008 Author Report Share Posted December 20, 2008 Is your router working? If the router isn't connecting to the internet properly, you'll get full wifi signal but no internet.Then try the obvious stuff - restarting the router/modem/ipod. Have you ever used the iPod for the internet at home? Is the WEP/WPA or whatever set up properly?yeh the router is working fine, and this is the first time ive tried the internet on it due too getting it today lol. yeh ive tried turning it all off and on again and re-connecting it, bummer :/ got any other things i should try? x Quote Link to comment Share on other sites More sharing options...
MattB Posted December 20, 2008 Report Share Posted December 20, 2008 Internet is sometimes very on/off on them.Try disconnecting from the internet and reconnect and enter the wpa or whatever. It sometimes worked.Matt Quote Link to comment Share on other sites More sharing options...
georgieporgie Posted December 20, 2008 Report Share Posted December 20, 2008 (edited) With my iphone i had the same problem...Have you got a belkin router?Basicly you have to get the right code (can be trouble as theres about a million codes on the box) but with my belkin none of them worked.I ended up just buying a homehub.. If you have a diffrent kind of box, just go to settings, wifi settings, connect to wifi, and it should come up with the box.Pm me if you still have troubles.. they sent me a huge document when i called.Cheers Edited December 20, 2008 by georgieporgie Quote Link to comment Share on other sites More sharing options...
cox. Posted December 20, 2008 Author Report Share Posted December 20, 2008 With my iphone i had the same problem...Have you got a belkin router?Basicly you have to get the right code (can be trouble as theres about a million codes on the box) but with my belkin none of them worked.I ended up just buying a homehub.. If you have a diffrent kind of box, just go to settings, wifi settings, connect to wifi, and it should come up with the box.Pm me if you still have troubles.. they sent me a huge document when i called.Cheersyeh thats the thing, i already have bt home hub. but its just being a pisshead. and yeah i know what you mean about the codes, which are on the back of the box i found the right one and enterd it into the password bit and i still dont work.. Quote Link to comment Share on other sites More sharing options...
ManxTrialSpaz Posted December 21, 2008 Report Share Posted December 21, 2008 yeh thats the thing, i already have bt home hub. but its just being a pisshead. and yeah i know what you mean about the codes, which are on the back of the box i found the right one and enterd it into the password bit and i still dont work..AFAIK the iPhone and touch show the signal strength of the strongest signal/one you've selected without actually being set up (being able to connect) to that connection. So you're gonna have to go through you're WiFi settings for your connection and set up accordingly. Quote Link to comment Share on other sites More sharing options...
Guest Posted December 21, 2008 Report Share Posted December 21, 2008 I have an ipod touch and i found it pretty intresting if you download an app called "wifinder" it lets you know alot more info about the router, that might help? no, i guess not. Quote Link to comment Share on other sites More sharing options...
