How Do I Tighten A Headset?
Mikey Tomo
Tighten stem and fork bolts. If i get you right. :unsure:Or maybe your headset just ended his life?
I love the way you put that!
You get whats known as a hammer and smash it to pieces then cry about it til you form into a pile of tears. x
You're not funny, be quiet.
Undo your stem bolts, tighten the bolt in the centre of the top-cap, then re-tighten the stem bolts.
If that doesn't sort it, check out your headset bearings and whatnot, then consider replacing it if it has "ended it's life" as the other poster said :P
Yea i was only joking, But as Skoze took the words right out my mouth to be honest. Just renember to do the middle cap bold up really tight so it pulls the headset in. x
I love the way riders give the bike the EVILS when they fall LMFAO
Edited by Onza t-vee rider jack :)
Don't do this.
Undo the stem bolts.
Tighten topcap bolt slightly, rock the forks back and forwards every turn or so.
Once it stops rocking and feels good stop doing the bolt up and do the stem bolts up.
If you tighten the topcap up it'll crush your headset bearings and you'll be f**ked forever. (or till you get a new headset)
Don't do this.
Nick knows where it's at ;)
It's common sense in this game to take it gently gently when bike pimpin'/fiddling, that's how threads get f**ked, bearings get crushed and civilisations collapse :mellow:
