zoo 06 Posted December 16, 2008 Report Share Posted December 16, 2008 hi ive just brought a chris king and i dont know what gear ratio to use and i havnt been riding long so i would like some advice. thanks rob Quote Link to comment Share on other sites More sharing options...
Zach Posted December 16, 2008 Report Share Posted December 16, 2008 I think it is ok, that is what my brother is running. Quote Link to comment Share on other sites More sharing options...
eskimo Posted December 16, 2008 Report Share Posted December 16, 2008 For mod, yes. For stock, no.18/12 is pretty much the standard for mod bikes of all sizes. Crank lengths is not. I ride 170mm on both mod and stock. Some ride 160mm or even 158mm on mod. Also some people with weaker legs ride 18/13 for a sightlier easier gear. But that's not recommended as it throws off your chainstay length and therefore brake adjustment. Quote Link to comment Share on other sites More sharing options...
Jake Beach Posted December 16, 2008 Report Share Posted December 16, 2008 I think it is ok, that is what my brother is running.Yep Zach that is what I am running on my mod, it is fine. Don't run it on a stock though. Quote Link to comment Share on other sites More sharing options...
zoo 06 Posted December 16, 2008 Author Report Share Posted December 16, 2008 what about if my rear sprocket was 16 what would my front sprocket be thanks Quote Link to comment Share on other sites More sharing options...
eskimo Posted December 16, 2008 Report Share Posted December 16, 2008 (edited) 24/16 will be the same as 18/12But it might not fit. The seatstay may rub so best to check first. Edited December 16, 2008 by eskimo Quote Link to comment Share on other sites More sharing options...
zoo 06 Posted December 16, 2008 Author Report Share Posted December 16, 2008 woul 24/16 be any good Quote Link to comment Share on other sites More sharing options...
Danny Metcalfe Posted December 18, 2008 Report Share Posted December 18, 2008 woul 24/16 be any goodjust go for 18/12 it's more common so any problems will be able to be solved by more people. Quote Link to comment Share on other sites More sharing options...
Sam F Posted December 18, 2008 Report Share Posted December 18, 2008 If ive got 16t upfront what do i have on rear? stock btw. Quote Link to comment Share on other sites More sharing options...
zoo 06 Posted December 18, 2008 Author Report Share Posted December 18, 2008 the only problem is that i dont have a front free wheel cuz i have a pro middle burn trials crank and it has 5 bolt holes on my chain ring so wats the smallest i can go.thanks Quote Link to comment Share on other sites More sharing options...
Anton Posted December 18, 2008 Report Share Posted December 18, 2008 If ive got 16t upfront what do i have on rear? stock btw.I run a 14 rear with mine. I guess it all depends what you find comftable? obviously there are a few people that ride a lower gear.Personal preference, keep trying till u find something you feel comftable with. Quote Link to comment Share on other sites More sharing options...
forteh Posted December 18, 2008 Report Share Posted December 18, 2008 the only problem is that i dont have a front free wheel cuz i have a pro middle burn trials crank and it has 5 bolt holes on my chain ring so wats the smallest i can go.thanks18:12 is a 1.5:1 gear ratio.The smallest 5 bolt sprocket for the middleburn pro trials bash is 20t, a 14t rear sprocket will give you 1.42:1 ratio.The normal middleburn chainring is 22t, in which case a 15t sprocket will give you 1.46:1 ratio.Both of which are slightly lighter than 18:12 gearing Quote Link to comment Share on other sites More sharing options...
Muel Posted December 18, 2008 Report Share Posted December 18, 2008 If ive got 16t upfront what do i have on rear? stock btw.I've got a 13t on the back with 16t on the front, it feels almost identical to my Echo, but the cranks are 12mm longer so it balances out the slightly higher ratio.I did have 16:14 but I couldn't get any speed for taps and couldn't gap properly. Quote Link to comment Share on other sites More sharing options...
zoo 06 Posted December 18, 2008 Author Report Share Posted December 18, 2008 18:12 is a 1.5:1 gear ratio.The smallest 5 bolt sprocket for the middleburn pro trials bash is 20t, a 14t rear sprocket will give you 1.42:1 ratio.The normal middleburn chainring is 22t, in which case a 15t sprocket will give you 1.46:1 ratio.Both of which are slightly lighter than 18:12 gearing what would you get, because i have only just started trials n dont know what to get. thanks Quote Link to comment Share on other sites More sharing options...
