maxpark3r Posted December 15, 2008 Report Share Posted December 15, 2008 Hi,Not sure what back brakes to get, I have heard from friends that hydraulic brakes , Magurra, are the best for a back wheel and that disc brakes are best in the rain also that v-brakes aren't very good so hopefully understandably I am a bit confused. Also is a disc brake on the front advisable and ok?Max Quote Link to comment Share on other sites More sharing options...
Skoze Posted December 15, 2008 Report Share Posted December 15, 2008 Hi,Not sure what back brakes to get, I have heard from friends that hydraulic brakes , Magurra, are the best for a back wheel and that disc brakes are best in the rain also that v-brakes aren't very good so hopefully understandably I am a bit confused. Also is a disc brake on the front advisable and ok?MaxOnly poor quality, poorly set up ones A disc is fine on the front on any bike, and a disc on the rear will be fine on a mod but not so much on a stock (I still used one and it was awesome)Matt Quote Link to comment Share on other sites More sharing options...
maxpark3r Posted December 15, 2008 Author Report Share Posted December 15, 2008 Only poor quality, poorly set up ones A disc is fine on the front on any bike, and a disc on the rear will be fine on a mod but not so much on a stock (I still used one and it was awesome)MattIf the V-brakes are the ones set up by a bike shop should I just leave them on or replace them?Max Quote Link to comment Share on other sites More sharing options...
Jack Chinnery Posted December 15, 2008 Report Share Posted December 15, 2008 If the V-brakes are the ones set up by a bike shop should I just leave them on or replace them?MaxHe means as in pads grind etc and something like an avid ultimate not a stock onza mate. x Quote Link to comment Share on other sites More sharing options...
Skoze Posted December 15, 2008 Report Share Posted December 15, 2008 If the V-brakes are the ones set up by a bike shop should I just leave them on or replace them?MaxThey might be set up quite well, but then again they might not. It never hurts to change it and find what you like He means as in pads grind etc and something like an avid ultimate not a stock onza mate. xYeah, decent pads, arms and cables are important, so are levers but to a lesser extent.A standard onza/tektro brake will never be as good as an avid ultimate Quote Link to comment Share on other sites More sharing options...
