Freewheels On The Rear
N.Wood
Whilst I should probably know this, would there be anything stopping me running an ENO on some sort of fixed 135mm hub?
Why don't people do this too often? Would be easier to change from my current set up to this rather than going FFW (and I like my trousers).
Cheers!
No reason not to. The only drawback is that you'd have to run a 22T front cog which is a bit on the big side by todays standards.
Edit: I should also point out that you wouldn't ruin your trousers running FFW provided you use a bashguard. I run my Inspired FFW with a GU bashring and have never caught my troos in it.
Something I had over looked! I guess this is the reason you don't see many around...
Edit: Interesting... The one bike I've ridden thats been ffw (had a bash) I caught my trousers in it, and happens pretty often to some beys round here all with bashguards.
