Onza Forks - Need Help.
maxpark3r
I got some trial forks for around £130, they look good and weigh nothing, I advise getting them considering that the Onza forks do weigh a ton.
(Y)
Thank you for the quick advice, by the way do u mean try-all forks?
I have just looked at them, they are very nice.
I am bit concerned I am wondering do they come with disc mounts?
Many thanks Max(Y)
Many thanks Max(Y)
Sorry, yes i meant try-all, and yes you can get them with either disc or magura mounts, and by the way they come in black or silver.
Pete.
Difference is, having £140 to spend on forks means he gets to choose from all of them.
The other thing being, if he goes for some echo ones, he'll likely have change.
Ok thanks, I think I might go for the cheaper forks or try and buy the try-all forks second hand.
Max(Y)
Max(Y)
If you have lots of money, try the try-all forx(x?)
I think the echo team forks are quite popular. Also, the echo SL ones are £74, which is quite a good price for some proper light forks.
Link.
Explain that then.
Reading that wasn't a pleasant experience, what with All The Capital Letters At The Beginning Of Every Word.
Get sum zoo! forks = £80-90 , echo lites around £60, or sum echo urban 20", all really good forks and then you still have money left over for other parts. I had onza ones and then as soon as i got my zoo! 's the weight so so much less XD
Adam (Y)
(Y)
if u are going to spend £130 on some forks you will have to have a good bike havent u got a onza t-bird and why have you got a pic of a onza bird and you ride a t-bird and if i remember you put forks on the rong way
Edited by robo
Hi robo check the rules sometime!
TXT language is not aloud and annoys many people so try and avoid it in the future.
Max(Y)
Why did you buy a onza T-bird if you have £140 spare woudent it of been easier just to get a higer spec bike?
A meen its like a £200 bike with £140 forks on its neerly 75% of what you paid for the bike???
find it silly reely. ???
It was the Onza Bird and it is £350, and it is because I am just starting so I got a low spec. bike, then eventually I will increase the spec. and the first thing I want to change are the forks.
Max(Y)
