BigAl Posted December 13, 2008 Report Share Posted December 13, 2008 Hi, today i re-sprayed my GU Typhoon and on the seatstay i accidentley sprayed to close and made a drip, i stupidley then tried to wipe the drip off with a cloth but this ruined all the paint surrounding the seatstay. Its all smudged and rippled, any suggestions as to what i could do to sort this out. Thanks. Alex. Quote Link to comment Share on other sites More sharing options...
grant_hundley Posted December 13, 2008 Report Share Posted December 13, 2008 Take the paint off and do that part again? Quote Link to comment Share on other sites More sharing options...
Mikey Tomo Posted December 14, 2008 Report Share Posted December 14, 2008 Take the paint off and do that part again?+1 Quote Link to comment Share on other sites More sharing options...
BigAl Posted December 14, 2008 Author Report Share Posted December 14, 2008 I tried that. The layers of paint around it are much higher,i sanded it down and tried to spray over it again but it looks wierd. Probabley just put a sticker over it. Ill put some pictures on to see what you guys think of it. Alex. Quote Link to comment Share on other sites More sharing options...
grant_hundley Posted December 14, 2008 Report Share Posted December 14, 2008 So you havn't taken it off properly? Quote Link to comment Share on other sites More sharing options...
BigAl Posted December 14, 2008 Author Report Share Posted December 14, 2008 I have its just in an akward place, i should just put alot of time into sorting it really, and more paint. Quote Link to comment Share on other sites More sharing options...
Mtchell Posted December 14, 2008 Report Share Posted December 14, 2008 Oright mate I maybe able to help am a painter and dec/sprayerWhat you want to do is sand down the affected area with some 60/80 grit sand paper to get the messed up paint offThen you want to sand the edges of the paint down to level them down to then metal (With a wet and dry sanding pad)so you don't have a blunt edge around the sanded area.Next you want to prime first , then build the paint back up, this will take a while, but as paint drys it expands and will fill the area again.If you want to have a really good finish, (when cured, after 5-7days) give the area a light T-Cut, polishing from the area outwards.Hope it helps Quote Link to comment Share on other sites More sharing options...
maxpark3r Posted December 14, 2008 Report Share Posted December 14, 2008 Try using methylated spirits to remove paint? that could work. Quote Link to comment Share on other sites More sharing options...
old_man_dan Posted December 14, 2008 Report Share Posted December 14, 2008 i wouldent recomend 60/80 grit it would be too harsh on a alloy frame. Your best bet would be to use 180grit wet then use 400 wet to get a better finnish, then when u spray only go in light coats the trick is to get the paint at a stage where it looks wet but dosnt run that wil give u the smooth finnish you are after. Take some time to practice spraying and learn how the paint adheres to the frame its the same with anything a bit of practice will help get the desired result. Quote Link to comment Share on other sites More sharing options...
Mtchell Posted December 14, 2008 Report Share Posted December 14, 2008 i wouldent recomend 60/80 grit it would be too harsh on a alloy frame. Your best bet would be to use 180grit wet then use 400 wet to get a better finnish, then when u spray only go in light coats the trick is to get the paint at a stage where it looks wet but dosnt run that wil give u the smooth finnish you are after. Take some time to practice spraying and learn how the paint adheres to the frame its the same with anything a bit of practice will help get the desired result.180 ??To take runs out he,ll be there all day !! Quote Link to comment Share on other sites More sharing options...
old_man_dan Posted December 14, 2008 Report Share Posted December 14, 2008 180 ??To take runs out he,ll be there all day !!yeh 180grit and it wil only take abought 5 mins if that. Im talking from alot of experiance 5 years in car body repair and spraying Quote Link to comment Share on other sites More sharing options...
BigAl Posted December 14, 2008 Author Report Share Posted December 14, 2008 Ok, i i've got lots of ideas now, ill try them and tell you how it goes, then put some pictures up to show you how great it looks:) Hopefully lolThanks alot. Alex. Quote Link to comment Share on other sites More sharing options...
Zach Posted December 15, 2008 Report Share Posted December 15, 2008 Try putting white spirt on it or sanding it down. Quote Link to comment Share on other sites More sharing options...
Mtchell Posted December 16, 2008 Report Share Posted December 16, 2008 yeh 180grit and it wil only take abought 5 mins if that. Im talking from alot of experiance 5 years in car body repair and sprayingOk I used 60/80 it was fine but you,ve pulled rank Quote Link to comment Share on other sites More sharing options...
Anton Posted December 17, 2008 Report Share Posted December 17, 2008 What you want to do is sand down the affected area with some 60/80 grit sand paper to get the messed up paint off ???? lol ive never heard anything so funny in my life.Just wet and dry it using a 400 grade then 800 grade. Make sure its all dry before u even attempt to spray again. You should be able to feel the difference with you fingers!.One more thing, dont just flat the bit the had gone wrong flat around the area as well or you will end up with nasty little pockets like the moon lol Good luck yeh 180grit and it wil only take abought 5 mins if that. Im talking from alot of experiance 5 years in car body repair and sprayingYeah im with you on the experiance :)But as you will know it will leave nasty scratch's which hell have to flat out to make it look pretty when its sprayed Quote Link to comment Share on other sites More sharing options...
faith Posted December 17, 2008 Report Share Posted December 17, 2008 Another way is find a local powder coat sprayer lolMy frames get done for £25 each which if u add up the price or primer,spray,laquer,papers,ect then its not far offand the quality is great also forms a genraly thicker coat great for trials dingsJust make sure its a reputible company and they will take care of your threads nicley Quote Link to comment Share on other sites More sharing options...
Anton Posted December 17, 2008 Report Share Posted December 17, 2008 Another way is find a local powder coat sprayer lolMy frames get done for £25 each which if u add up the price or primer,spray,laquer,papers,ect then its not far offand the quality is great also forms a genraly thicker coat great for trials dingsJust make sure its a reputible company and they will take care of your threads nicleyyeah nice idea... i had one of my old pashley 26mhz frames sand blasted and powder coated in satin black £60 frame and forks (poor thing is now pink lol) Quote Link to comment Share on other sites More sharing options...
mattyboi Posted December 21, 2008 Report Share Posted December 21, 2008 Well unlucky but i did the same recently as well,1. make sure the paint around is completley dry (leave for 24-48hours)2. get some sand paper not to coarse/sharp and clean of the messed paint3. give it a good clean on the part to respray and dont go to heavy4. give a good spray read the can they usualy tell you the best distance to stay away from the object to avoid drips and if its a gloss paint the gloss not spraying on like it did on myne :@Hope this helps,Matt Quote Link to comment Share on other sites More sharing options...
