Bunnyhop And Other Streety Moves
DARkON
on my other bike, stumpjump hardtail, i was able to bunnyhop pretty well for me.
on my adamant, +45 BB and 1090 wb, i can clear tall street curbs. that is about 1/3 to 1/4 the height of the stumpjumper.
is there a way to make my adamant for bunnyhop friendly?
i'd also like to get into manuals. however, i've never worked on manualing an other by beside the adamant.
here are some of my parts. im not sure about any more specific specifications per part.
Adamant A1 long 135mm rear spacing 1090sb +45bb
Zoo 4 bolt CNC’d fork
FSA PIG headset
Echo stem
Echo Riser bar
Rogue Grips
Magura HS33 brakes
Rock trials brake pads
Echo 4 bolt brake mounts
Moe Trials 128mm BB ISIS
Echo CNC stock crank isis
Eno Front freewheel 18T
Echo bashring
VP caged pedals
KMC Kool chain 3/32”
Echo front disc hub laced to front Echo rim 32H
Echo rear fixed hub laced to rear Echo rim 32H
also, i've been tossing around the idea of getting an Inspired Fourplay and using a number of my adamant's parts to build up the Fourplay.
thoughts advice criticisms w/e
thanks
austin
Your Adamant's built up so that it will be comfortable on the backwheel and therefore not so good for streety stuff. If you want to be able to do bunnyhops, manuals etc it would probably be best to look at getting a new frame. If you want to make your Adamant more streey you could try riser bars and a shorter stem amybe?
A long wheelbase, high bb bike is always going to be hard to bunnyhop! I'd say that if you really wanted to get into streetier stuff, get a shorter frame, of try a 24".
It's not impossible to bunnyhop long bikes, just an awful lot harder than on a hardtail/ street bike etc.
I'd recommend a higher stem/ bars first of all, makes a husge difference! Try and get the front end as light as possible too.
If you think you'd like to have a go at a 24", i'd say just go for it. Are ther any riders near you who ride 24"? If so, have a go on their bikes on rides, i don't think you'll be disappointed!
Just keep practicing, it'll come in time,
Matt
Edited by Skoze
That's a popular misconception. High bb bikes are difficult to bunnyhop because of the stems that are used. The rise itself makes bunnyhops easier. For example, a Control with a short and low stem will be much more difficult to bunnyhop than an old A1 with the same stem
Generally the shorter the stem, the easier it is to bunnyhop a frame. But with high bb bikes, a short stem is jolly uncomfortable. Perhaps change over to a different frame?
great replies! I have seen some really big bunny hops and manuals on trials bikes. I've just never seen me do it. 8P
i've considered a new frame, but i am one of maybe two trials riders and among a very slim pickings when it comes to non-BMX street bikes in Oklahoma. That makes trying other bikes difficult.
I will try a new stem for sure, now.
Fourplay
Reach from centre of BB shell to centre top of head tube: 650mm (25.5")
A1
Centre of BB shell to top centre of head tube: Short 665mm (26.25"), [Long 675mm (26.5") <--- mine is the long version]
is this measurement parallel toptube length? how noticeable would this change be, the 675mm to the 650mm?
a new frame was recommended a few times. any suggestions on which frame or what i'd be looking for in a different frame?
thanks guys
here's a pick of me and the bike in my backyard on an obstacle i fashioned (before brake booster and rear wheel grind) like a face to a name, a bike to a discussion 8D
It's not parallel, it's the distance from the BB to the Headtube. Centre to Top. (as said)
So it's not really a safe measurement in some cases. Because the BB height and Headangle can throw it off. But also it's kinda of a shit/ worthless measurement if you don't take the stem into consideration.
My A1 would manual and bunny hop but it wasn't great. Also 180s were a laugh because it just felt stupid. I just used a whole pedal stroke to bring the bike up and spin it. I reckon you should try a short frame, like the 07 Pitbull or Control?
Once you are up then it will be boss for manuals - as the balance point on trials bikes are so easy to lock into. I would also say dont sacrifice your stem length either - a short stem on a proper trials bike is completely pointless, from the picture it looks quite low - so you could get a higher rise one leaving those spacers in? should straighten up your body position and make it easier to pull up the bars.
Once you've mastered the technique of a proper bunnhyop it is easier to hop a bike with a long wheelbase higher. For example on a bmx with a small wheelbase. The front is piss easy to lift up but you can only reach a certain height hopping without making it oober difficult. Its hard to explain but because the wheelbase is short, the front wheel can't be too high off the ground before you lift the back up, otherwise you come to far back (can't level out intime and have overcooked the balance point as it where).
However on something like a zoot or a foreplay. The front is really hard to lift up but will be really easier to hop 1m+. I could bunnyhop my zoot easily rail height before i sold it, you just have to yank the front up with everything you've got and then throw the back up. I could hop my zoot 10x higher than my 20.4" TT bmx........
I disagree! I think the adamant with the same stem as on the echo would be much harder to bunnyhop!
my tips for better bunnyhops:
1) higher stem
2) shorter stem
3) more backsweep on bars
4) more body English
That will make them easier, but your still not going anywhere if you don't put in the effort.
Tried it 2 years ago using a very short Onza stem on an A1 06' and it made me land on my back at the first bunnyhop attempt. It really made the bike dead easy to bunnyhop. I compared that to an '04 Pure which was much more difficult.
I've found my 07 A1 easier to bunny hop/get on the rear wheel than my 04 control - personally, I think it is down to the slightly shorter chain stays (380 instead of 385).
Try a higher (not shorter) stem. I've got a trial tech stem and pretty flat bars which are similar to zoos etc and I can still bunny hop it about 44" on a good day. (I am 6'4" - may make a difference).
it is a BBB highrise OS 110mm @ 25 degrees. it uses 6061 aluminum and 4 mm hex keys on the hbar bolts not 5 or 6 mm bolts like others. echo uses 7075 t6 al. i am not confident in its strength.
idk much about the company and i am _not_ going to keep it permanently for strength confidence reasons.
i'll just have to find a trials/DH stem similar to it.
i am know tarty bikes has a slew of options for stems, i've looked.
