V Brakes On My Mod ?
Jack.lad
eloo there , i have a monty 221 pr with the standard magura louise disks on it but i was thinking about changing to vee brakes ? i was looking at the shimano xtr's then use some plazmatics or heatsink pads on it . but would it be a good idea to do this to my monty or not ?
cheers Jack
IT depends what you want froma brake too!
Most vees tend to have alot less bite than a magura, so if you can cope with that, go for it! They have insane hold, though.
Try heatsink adapters, if you use the middle hole, *hopefully* there won't be too bad-a-clearance issue (Y)
