Otacon Posted December 13, 2008 Report Share Posted December 13, 2008 Hey, I have chris king classic hub, with alloy driveshell. The driveshell has a cassete on, the first 3 cogs have come off fine, but the rest i can not get off for nothing, i think the cogs have dug in the driveshell really badly.Any reccomendations for getting them off ? Quote Link to comment Share on other sites More sharing options...
faith Posted December 13, 2008 Report Share Posted December 13, 2008 Hey, I have chris king classic hub, with alloy driveshell. The driveshell has a cassete on, the first 3 cogs have come off fine, but the rest i can not get off for nothing, i think the cogs have dug in the driveshell really badly.Any reccomendations for getting them off ?with the lower range gers in place u should be able to see how bad they are stuck in u need to get tention in both direction on the casset at the same time so...1.put the lower range cassett cogs back on2.replace lock ring but do not do up tight just enough to take up most of the slack in the cassett3.get 2 chain whips or chains with screwdrivers throu wrap around the higher and lower gears in oposing direcions4.pull in both directions hopefully the poressure will help dislodge the rear section of the cassett.failing that if u have one u can strip with allenkeys in the rear of the body undo those and the casset will/should fall to pieces and work on removing one section at a time. Quote Link to comment Share on other sites More sharing options...
