Mikey Tomo Posted December 12, 2008 Report Share Posted December 12, 2008 Ok, I want some tips from the pros At the moment I cannot pedal kick and would like to know some tips on how to do them. I have seen the Ryan leech tips and they do not seem to be working for me yet. So all help wanted no matter how big or small. And i also have been on Trashzen and it just does not work for me. Quote Link to comment Share on other sites More sharing options...
Mikee Posted December 12, 2008 Report Share Posted December 12, 2008 I ha the same problem when i started. What i did was just keep trying and then i was able to do more and it was more controlled untill i finally nailed it. Quote Link to comment Share on other sites More sharing options...
Jamie_Trials Posted December 12, 2008 Report Share Posted December 12, 2008 OK i may not be a pro but I can still do pedal kicks1- get into a stance where you are able to get your front wheel up in the air slowly2- slightly kick your pedals but with your ankles relaxed (probably just 1/8th of a whole turn on crank)3- feather the brake to make your front wheel to go down (the further it goes down the front wheel goes the further forwards you will go)4- carry on doing step 2 and 3 Also you can check out TrashZen It has lots of trialsing tutorialsHope this helpedJamie Quote Link to comment Share on other sites More sharing options...
Mikey Tomo Posted December 12, 2008 Author Report Share Posted December 12, 2008 Yeah thanks for the help I did not know you had to wait for the front wheel to lower haha I thought you just pedaled randomly Quote Link to comment Share on other sites More sharing options...
davey1991 Posted December 13, 2008 Report Share Posted December 13, 2008 Yeah thanks for the help I did not know you had to wait for the front wheel to lower haha I thought you just pedaled randomly You need to be in a similar position to when back hoping,pre load on your pedals with front wheel on the air, let go on the rear brake and kick forward 1/8 to 1/4 of a turn while in the air get control of the brake again.once you land featherthe brake so you dont slam into the floor.similar for gaps. Quote Link to comment Share on other sites More sharing options...
Sidehop Stuart Posted December 13, 2008 Report Share Posted December 13, 2008 Learning to back hop and balancing on the back wheel may help too.When I begin sidehops I find that balancing really helps before kick hopping into it. Quote Link to comment Share on other sites More sharing options...
