Viz Extreme 120ep Rear Hub
Rusevelt
Is that just the bearings that have self destructed or the ratchet system?
Looks like bits of hub/drive shell. Im guessing some bearings have collapsed and its chewed itself to pieces, the ratchet ring and bearings would be in hardened steel as such wouldnt produce swarfe like that :)
Believe it or not the bearings are all still perfect. To save weight the freehub body is aluminium while the carrier for the ratchet pawls is steel. The freehub body threads onto the carrier. The threads on the pawl carrier have snapped off and chewed up the threads in the freehub body. You can still see the threaded ring which used to be part of the pawl carrier wedged into the freehub body in the second picture.
The moral of the story anyway is that this hub isn't up to XC use, not to mind trials.
Industry nine are the next ones to try - only other 120 click hub on the market AFAIK...
I'm looking for something to match the reliability of Shimano XTRs from 2002 ish. They'd run for 6 or 7 years with no maintenance at all. Only downside is they only have 16 clicks, so pick up on drive is a bit crappy, even for XC use. I snapped an axle in the current model XTR hub (32 clicks in the freehub) after about a year's XC use, so they're also junk unfortunately :(.
Kings need too much minding to stay going as XC hubs. The 3-6 month strip and relube maintenance schedule they reckon the hubs need with a full rebuild every year is a hell of a lot more than I'd ever bother with - for trials where they're not routinely exposed to mud, rain and mileage, King hubs are a great choice (Though I prefer my ENO).
Industry nine might be the next ones I'll try - have to see if Superstar will give me warranty cover...
