16 years later Posted December 10, 2008 Report Share Posted December 10, 2008 I just ordered a Rohloff chain tensioned and I was just wondering how you adjust the chain line.Any help much appreciated.Thanks Bruce Quote Link to comment Share on other sites More sharing options...
Ross McArthur Posted December 10, 2008 Report Share Posted December 10, 2008 You get shims with it so you can put them inbetween the hanger and the bolt to space it out the way.You can also space your hub spacers out if need be. Just have a play around to see whats best with the front chain ring. Quote Link to comment Share on other sites More sharing options...
Cookyboy Posted December 10, 2008 Report Share Posted December 10, 2008 Should be fine with most setups as it does come with spacers, however if you have a weirdly spaced rear hub like the old style echo it wont work. Quote Link to comment Share on other sites More sharing options...
16 years later Posted December 10, 2008 Author Report Share Posted December 10, 2008 (edited) Should be fine with most setups as it does come with spacers, however if you have a weirdly spaced rear hub like the old style echo it wont work.Thanks for the help guys.I have a chris king so should be ok?Thanks Edited December 10, 2008 by 16 years later Quote Link to comment Share on other sites More sharing options...
tryallmaster Posted December 10, 2008 Report Share Posted December 10, 2008 Thanks for the help guys.I have a chris king so should be ok?ThanksWill be fine mate, its all trial and error till you get the chain to run smooooooothly... Lewis. Quote Link to comment Share on other sites More sharing options...
