faith Posted December 9, 2008 Report Share Posted December 9, 2008 just wondering i have a avid bb7 for the front of my stock when it gets built,would a bb7 on the rear be substantial enough?also how reliabal are these brakes in comparason to say a standerd magura rim brake? Quote Link to comment Share on other sites More sharing options...
Sidehop Stuart Posted December 10, 2008 Report Share Posted December 10, 2008 I used a Hayes mx2 on the front ages ago and it worked very well.I'm sure they'll work just as good on the rear Quote Link to comment Share on other sites More sharing options...
forteh Posted December 10, 2008 Report Share Posted December 10, 2008 I tried a bb7 on the rear and it was shocking, reasonable bite but zero hold. It was bedded in properly but was only a 185 disk (couldnt fit a 203 in the frame) but no matter what I did it wouldnt hold.Went back to magura, its lighter and works better on the rear.Im sure that someone may have used a bb7 successfully on the rear of a stock, but for me it didnt work. Quote Link to comment Share on other sites More sharing options...
Skoze Posted December 10, 2008 Report Share Posted December 10, 2008 I ran a 200mm hope on the rear of mine, was absolutely awesome!It slipped occasionally, but only when i seriously missed something.BB7s are great on the front, not so much on the back - for me you get no response from them, and it just feels a bit dead.For the price of a new BB7, you could get a second hand Mono Trial easily! Quote Link to comment Share on other sites More sharing options...
faith Posted December 10, 2008 Author Report Share Posted December 10, 2008 unfortunatley not for the price i would get it for lol i idealy dont want 2 difrent leavers so may go for a frame i can fit full magies to or a avid v on the rear to go with the bb7 front Quote Link to comment Share on other sites More sharing options...
Skoze Posted December 10, 2008 Report Share Posted December 10, 2008 They do work well on the rear, just i personally don't like the on/off braking, a bit of modulation is always nice! Quote Link to comment Share on other sites More sharing options...
ilikeriding Posted December 10, 2008 Report Share Posted December 10, 2008 good because it doesnt matter if you bend your front wheel but bad because theyere verry flexxy although they are really powerful when set up right Quote Link to comment Share on other sites More sharing options...
Jitters Posted December 10, 2008 Report Share Posted December 10, 2008 Now you guys have me wondering.Mentioned in a post a while back I was getting a set of Avid discs for my stock build for doing some freelance art for a company. Believe it's the Juicy 7s. Suggestions mentioned I should consider 203mm rotors front/rear. I like the on/off type braking, personally, but should I reconsider? Quote Link to comment Share on other sites More sharing options...
Skoze Posted December 10, 2008 Report Share Posted December 10, 2008 Now you guys have me wondering.Mentioned in a post a while back I was getting a set of Avid discs for my stock build for doing some freelance art for a company. Believe it's the Juicy 7s. Suggestions mentioned I should consider 203mm rotors front/rear. I like the on/off type braking, personally, but should I reconsider?Yeah, 203's will be fine (in fact, i wouldn't run any less on the rear of a stock)I'm not too sure on Juicy 7s, never had any experience of them on a trials bike, good brake though! They may be a bit more like the Mono Trial than the BB7 (because they're hydraulic, obviously) a bit of modulation on the rear isn't a problem, but you can easily set the brake up for on/off braking if you really want to (or just pull the lever a bit harder/faster like i do )I just find that hydro can feather a hydro brake, whereas big cable discs are far hearder to do that with. Quote Link to comment Share on other sites More sharing options...
Jitters Posted December 10, 2008 Report Share Posted December 10, 2008 Well, I'll be the test subject then. It'll take me a while to get the project done, but will report the results when the time comes. thanks for the input Skoze! Quote Link to comment Share on other sites More sharing options...
El Cristoff Posted December 10, 2008 Report Share Posted December 10, 2008 I have a BB7 on the rear of my 24UK and i love it. Holds well, nice amount of modulation, bites great. I would really recommend it Quote Link to comment Share on other sites More sharing options...
PaRtZ Posted December 11, 2008 Report Share Posted December 11, 2008 On a mod they are fine, but on your stock, no no no!Although they work and can work ok, maguras/vee's are much better and reliable, so go with them. On the front though 203mm wil be the dogs bollocks Quote Link to comment Share on other sites More sharing options...
stu powney Posted December 12, 2008 Report Share Posted December 12, 2008 just wondering i have a avid bb7 for the front of my stock when it gets built,would a bb7 on the rear be substantial enough?also how reliabal are these brakes in comparason to say a standerd magura rim brake?bb7 with a 185 rotor n organic pads works betta than most breaks u can get...b sure to get a good cable and a linner outer to make it work smoother..dont over pull the leaver arm though ajust it so it has a good feel or ul snap it...205 rotor can snap forks to its to much for trials...just a good set up will do u well front or rear..just wondering i have a avid bb7 for the front of my stock when it gets built,would a bb7 on the rear be substantial enough?also how reliabal are these brakes in comparason to say a standerd magura rim brake?bb7 with a 185 rotor n organic pads works betta than most breaks u can get...b sure to get a good cable and a linner outer to make it work smoother..dont over pull the leaver arm though ajust it so it has a good feel or ul snap it...205 rotor can snap forks to its to much for trials...just a good set up will do u well front or rear.. Quote Link to comment Share on other sites More sharing options...
