Try All Front Disc 28h + Try All Rim 28h
Rafal
Hi, i'm waiting for try all front hub 28H (that 100g) and try all 28h rim. Anyone have the same set? I would like to know what length of spokes should i buy.
disc side - 3 cross lacing
right side - radial or 3 cross ( i dont know what will be better, give me some advice and your conf, thanks)
cheers, pisanka
Edited by Rafal
They are usually built radial on the non disc side of the hub, I would use this as it is hard to lace 3 cross with such a small flange (Y)
Disc side: 266mm 3x
Other side: 256mm radial.
Adam
Edit: Oh and that is 26"...
Its what I'm rolling on (well, the older version) and its been fine for a couple of years now.
The only problem I've had is the disk side spokes snapping, think I went through all 14 of them because they appeared to be cheap shitty plain guage ones. Swapped them to DT's and now its golden.
