laurent Posted December 5, 2008 Report Share Posted December 5, 2008 I use the search function but i can't find all information i want...so i ask you.Anyone knows which is the "riser" riser bar on the market?I think it's the rockman but i'm no sure because i can't find specification of all the bars.My goal is to have a higher position on the bike an more "room".Thanks! Quote Link to comment Share on other sites More sharing options...
Bionic Balls Posted December 5, 2008 Report Share Posted December 5, 2008 yes risen riser bars are higher Quote Link to comment Share on other sites More sharing options...
Bigman Posted December 5, 2008 Report Share Posted December 5, 2008 Rockman, Try-all Rage, Trialtech and Monty are "true" riser bars unlike the deng attempts which may as well just be flat as they provide very little gain in height/cockpit room. Monty and Try-all rage bars are quite narrow, around the 27 - 27.5inch mark which for alot of people is abit too narrow, my monty bars were extended to around 29.5inch and they were very comfortable, i then had a set of trialtech, out of the true riser bars i would say that these have the least actual height gain, but they are very comfortable and are around the 29inch width mark, recently i have moved to Rockman bars as part of my sponsorship, they felt very different to the trialtechs when i first rode them, but after a afew hours i was used to them and getting on with them as well as the trialtechs, they are higher than the trialtechs but not as wide at around 28inchs.They are all very good bars, although i have heard of Rage bars snapping, monty, rockman and try-all are slightly higher than the trialtech ones, but the trialtech are slightly wider, if you can try and have a go on different peoples bikes with the different bars and see which you prefer.Adam Quote Link to comment Share on other sites More sharing options...
eskimo Posted December 5, 2008 Report Share Posted December 5, 2008 I think you are looking for bars with up-sweep?As for trials specific bars, it's the ones specified. Also Viz Max bars offers more up-sweep than the Deng range but not quite as much as Trialtech bars. They are probably the widest going but don't flex like the Deng range. It's also worth looking at flat bars. Most people put them off, but they do offer a really nice comfort to riding on the back wheel.There's also quite a few mtb bars that seem alright. I was looking into it a while back but just stuck with my Max bars. How about these?Only joking, those would snap easily no doubt. Quote Link to comment Share on other sites More sharing options...
Rusevelt Posted December 5, 2008 Report Share Posted December 5, 2008 Neon High Riser bars, would be the highest if you angled the bars so that the bar end is positioned at 12 o'clock. followed by TryAll, Trialtech, Rockman, Monty, and other risers of simular rise, up-sweep, and back sweep geometry. Quote Link to comment Share on other sites More sharing options...
shamus Posted December 5, 2008 Report Share Posted December 5, 2008 I'm running try-all rage. seem loevly and comfy for me. And they did add loads of room to my cockpit, but as others say they are narrow ish (compared to my brisa's ), my wheel swaps and power lift moves did suffer but for rolling moves they are so much nicer Quote Link to comment Share on other sites More sharing options...
laurent Posted December 5, 2008 Author Report Share Posted December 5, 2008 Thanks guys for all these answers!Especially Bigman for your precision.I think i'll buy the one with the better "width/rise" ratio. So i'll probably go for the rockman even if the shape of this bar seems very strange.Thanks again! Somme very helpful information here! Quote Link to comment Share on other sites More sharing options...
Bigman Posted December 6, 2008 Report Share Posted December 6, 2008 I think i'll buy the one with the better "width/rise" ratio. So i'll probably go for the rockman even if the shape of this bar seems very strange.It only feels strange to begin with, as with any handle bar when you change, once you are used to them i am sure you will like themAdam Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted December 8, 2008 Report Share Posted December 8, 2008 i personally really like my new style zoo bars...but thats just me Quote Link to comment Share on other sites More sharing options...
Muel Posted December 8, 2008 Report Share Posted December 8, 2008 He wants bars with a proper rise, not almost none. Quote Link to comment Share on other sites More sharing options...
Ben H! Posted December 8, 2008 Report Share Posted December 8, 2008 I'd of said for the proper risers bars are the trialtech ones & the montys or the rockmans as well Ben. Quote Link to comment Share on other sites More sharing options...
Sponge Posted December 8, 2008 Report Share Posted December 8, 2008 The older ZOO bars from 2005 are great if you can get your hands on them. The Trialtech risers are an identical copy of their geometry. Great bars Quote Link to comment Share on other sites More sharing options...
Greetings Posted December 8, 2008 Report Share Posted December 8, 2008 The older ZOO bars from 2005 are great if you can get your hands on them. The Trialtech risers are an identical copy of their geometry. Great barsThey're not, Trialtechs have more rise. Quote Link to comment Share on other sites More sharing options...
Sponge Posted December 8, 2008 Report Share Posted December 8, 2008 I've compared both in my own hands, and compared when attached to stems. They are the same in rise, and width. I guarantee. You must have a 2006/2007 edition then. The actual high-rise Zoo bars from 2005 are identical to Trialtechs. I can promise that. Quote Link to comment Share on other sites More sharing options...
Greetings Posted December 8, 2008 Report Share Posted December 8, 2008 Fair play, perhaps Zoo bars came in 3 versions. The Zoo's I compared the Trialtech to weren't the 20mm risers from the last 2 years released alongside the Adamant and GU bars. Quote Link to comment Share on other sites More sharing options...
laurent Posted December 8, 2008 Author Report Share Posted December 8, 2008 i bought à Rockman bar...because it's seems to be the "riser" one!I'll see soon if i like it or not! Thanks for the advice guys Quote Link to comment Share on other sites More sharing options...
16 years later Posted December 9, 2008 Report Share Posted December 9, 2008 i bought à Rockman bar...because it's seems to be the "riser" one!I'll see soon if i like it or not! Thanks for the advice guysLet us know what there like. Quote Link to comment Share on other sites More sharing options...
laurent Posted December 10, 2008 Author Report Share Posted December 10, 2008 Let us know what there like.i received the handlebar this morning, the color is actually a bit weird, but i quite like the shape.I'll test it as soon as i can ride....not so soon because of the snow outside!I'll let you know if i like to ride with it and if it's a good handlebar. Quote Link to comment Share on other sites More sharing options...
