jack0174 Posted November 29, 2008 Report Share Posted November 29, 2008 I am in the process of stripping my frame and have almost finished but i cant get to the arkward places.To strip it im using paint stripper and i also have some sandpaper to can you please give me some tips to get to the arkward places?Thanks. Quote Link to comment Share on other sites More sharing options...
mike137 Posted November 29, 2008 Report Share Posted November 29, 2008 A long 1" wide paint brush should do the trick, with some nitromores on the end of it, or perhaps a dremel with a long bit on the end and a wire wheel? Quote Link to comment Share on other sites More sharing options...
davey1991 Posted November 29, 2008 Report Share Posted November 29, 2008 A long 1" wide paint brush should do the trick, with some nitromores on the end of it, or perhaps a dremel with a long bit on the end and a wire wheel?or if its really small bits, pick of the paint with the end of a nail, then sand it smooth afterwards, what i did on my cranks. Quote Link to comment Share on other sites More sharing options...
Adam Fisher Posted November 29, 2008 Report Share Posted November 29, 2008 A long 1" wide paint brush should do the trick, with some nitromores on the end of it, or perhaps a dremel with a long bit on the end and a wire wheel?Use nitromores , its in Mr Muscle cleaning agents . Just apply a small amont in the area where needed , leave for 5 mins andthe scrub with a old toothbrush. Extremly easy with great results. Quote Link to comment Share on other sites More sharing options...
jack0174 Posted November 29, 2008 Author Report Share Posted November 29, 2008 So is nitromorse much better than ordinary paint stripper?Because with the stripper i have got i have tried that technique but it just smudges the paint on to the frame more. Quote Link to comment Share on other sites More sharing options...
mike137 Posted November 30, 2008 Report Share Posted November 30, 2008 So is nitromorse much better than ordinary paint stripper?Because with the stripper i have got i have tried that technique but it just smudges the paint on to the frame more.Nitromores is a brand name, it is just paint stripper, but it does what it says on the tin (no, its not made by Cuprinol). Comes in a green tin/bottle thing. Quote Link to comment Share on other sites More sharing options...
Gogz- Posted November 30, 2008 Report Share Posted November 30, 2008 So is nitromorse much better than ordinary paint stripper?Because with the stripper i have got i have tried that technique but it just smudges the paint on to the frame more.It might be a good idea trying to scrape it off instead Quote Link to comment Share on other sites More sharing options...
jack0174 Posted November 30, 2008 Author Report Share Posted November 30, 2008 This may sound a bit wierd but i put the stripper on waited for about 5 mins then blasted it off with a hosepipe it kind of worked but not quite fully and i still have some paint left to strip. Quote Link to comment Share on other sites More sharing options...
Adam Fisher Posted December 3, 2008 Report Share Posted December 3, 2008 This may sound a bit wierd but i put the stripper on waited for about 5 mins then blasted it off with a hosepipe it kind of worked but not quite fully and i still have some paint left to strip.You have to do it a few times , just treat the areas again where the remaining paint is. Quote Link to comment Share on other sites More sharing options...
