Gear Ratios
Jack Chinnery
Usually most mod riders use 18:12. You change how hard the gearing feels based on the length of your crank. 18:12 with 160 mm length cranks feels quite hard, similar to 18:15 with 170s on a stock. The longer the crank, the lighter the gearing will feel. I'd recommend 18:12 with 165 or 170 mm length cranks.
Edited by Jason222
ok cheers.
