A Good Way To Take Off Grips? (without Cutting)
RETROLEO
hair spray under them. (using a screw driver etc. to lift them) then twist them off if they have the ends that cover the hole in the bar you can use a football pump fitting and block the opposite side. Blowing down the bar with the other end blocked works for some grips as well.
