pizzapie.. Posted November 12, 2008 Report Share Posted November 12, 2008 evening everyone,You all okay?any way,i was thinking of building my old zona zip as my gu le 08 mod was stolenon the zona should i go back magura or vee brakemy magura is old style lever braided hose braided cross over zoo booster echo clamps pads,well i dont ave any atm but could i have some segestions on what pads to run my vee brake avid sd5 lever avid sd5 arms adapters onza 4 bolt (not got them yet) plaz pads (not got them yet) outland vee booster slik cablethanks liam Quote Link to comment Share on other sites More sharing options...
trials13boy Posted November 12, 2008 Report Share Posted November 12, 2008 (edited) hi personally go for the maggie as they are more powerful and for pads go for a set of heatsink as they're so grippy Edited November 12, 2008 by trials13boy Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted November 12, 2008 Report Share Posted November 12, 2008 hi personally go for the maggie as they are more powerful and for pads go for a set of heatsink as they're so grippyHelpful Personally, I'd go for the magura. BUT get standard(plastic) hosing, because in my opinion braided makes the brake feel spongy. As for pads, a set of Koxx Blues and a good grind will do you nicely for these wet, winter months. Quote Link to comment Share on other sites More sharing options...
Trials... Posted November 12, 2008 Report Share Posted November 12, 2008 hi personally go for the maggie as they are more powerful and for pads go for a set of heatsink as they're so grippyScott, 1.You probably have never rode with Heatsinks. 2. Who is the one about to go rear vee????Peace out Quote Link to comment Share on other sites More sharing options...
craigjames Posted November 12, 2008 Report Share Posted November 12, 2008 (edited) magura's arent more powerful at all. my vee owns the majority of magura set ups. avid ultimate arms, pazmatic crvs on a light grind or smooth rim are the best pads ive used, and ive tried a few. the vee has better hold, just as good bite but some dont like the feel, thats just the way i have mine set up. it really does hold when it really shouldnt. and theres less to go wrong. Edited November 12, 2008 by craigjames Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted November 12, 2008 Report Share Posted November 12, 2008 (edited) magura's arent more powerful at all. my magura owns the majority of magura set ups. avid ultimate arms, pazmatic crvs on a light grind or smooth rim are the best pads ive used, and ive tried a few. the vee has better hold, just as good bite but some dont like the feel, thats just the way i have mine set up. it really does hold when it really shouldnt. and theres less to go wrong.Vee? Edited November 12, 2008 by BenJohn-Hynes Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted November 12, 2008 Report Share Posted November 12, 2008 i had a maggie for years, recently went vee, it broke, put a dengura with maggie slaves on (love you prawny) and its damn good, im loving maggie again. vee was just shit to be honest, and it was a good set up. Quote Link to comment Share on other sites More sharing options...
bigamac Posted November 12, 2008 Report Share Posted November 12, 2008 (edited) I don't really know anything about brakes etc. But do you know the weight of your zona frame?I might buy one soon.Would you recommend it? Edited November 12, 2008 by bigamac Quote Link to comment Share on other sites More sharing options...
eskimo Posted November 12, 2008 Report Share Posted November 12, 2008 Vee brakes on the rear can be annoying as they don't really bite. Added with the close pads on a buckled rim it's kind of a pain and modulation is better on a Magura. But they both have their advantages. I like Hydraulic brakes in general, but when it comes down to it i prefer cable for one reason; they don't break as easy. Quote Link to comment Share on other sites More sharing options...
Ali C Posted November 12, 2008 Report Share Posted November 12, 2008 magura good points:pretty reliable mud and grime doesn't effect them as muchgood bitelighterMagura bad points:When they go wrong, they are harder/more expensive to fix.hold power isn't the bestpads wobble so you can feel them knocking and they wear oddly/get rounded cornersloudnot much modulation unless with smooth rim and black padsVee good pointsUnreal holding power, MUCH better than a maguramore modulation even with a grindeasier to pull than a maguramore adjustablepads don't wobble and are easier to changecan get the rear wheel out without deflating the tyrecan get spares nearly anywhere in the world for cheapVee bad pointsneed more work to keep smoothcan be expensive for a top setupnot much bite (from my 3 years experience)heavierlooks worseinitial setup can be trickyDon't be fooled when people say maggies have more power. They may indeed have more bite, but vees are like clamps on your rims when the wheel is trying to roll backwards.I used a vee for 3 years, although I have now moved to an Echo TR brake just to see if they are any good. so far I like the bite power, but I am still shocked by the lack of holding power. Quote Link to comment Share on other sites More sharing options...
grant_hundley Posted November 12, 2008 Report Share Posted November 12, 2008 You all okay?Yes thanks, how are you? Quote Link to comment Share on other sites More sharing options...
MiuSliS Posted November 12, 2008 Report Share Posted November 12, 2008 Pretty much everything was cover up. Vee indeed have more hold power, but sometimes mag are better. Thing is that usually frames are with 4-bolts mounts and you need the vee adapters. Several my friends combined already snapped like 5 or 6 pears of vee adapters! Besides vee can be expensive and hard to adjust if you want maximum power from them. So maybe testing will show you what you prefer. Less hold power, but I'd go magura. Quote Link to comment Share on other sites More sharing options...
Connor Powell Posted November 13, 2008 Report Share Posted November 13, 2008 Ive used vee and magura on the front both with plazmatic pads on a smooth rim, and i would recommend going for a magura, my vee brake was awful, it lacked in everything. Power, Hold, Bite and the lever felt horrible. It was impossible to set up, the left hand arm always rubbed on the rim. I had this set up with my vee. Shimano Xl 2008 arms, Plaz crv's, Oddessy Slic linear Cable and a Avid sd7 lever. All of it was brand new.So basically in my view these are the pros and cons of both.Vee Pros:Umm.Vee Cons:Hard to set up,Pads wouldn't hit square,Awful feel to the lever,Awful hold, power and bite. Magura ProsEasy to set up,Better lever feel,More power and you can have modulation,More choice of pads.Magura Cons :Can snap hoses,Can crack slaves and lever body.Tpas break,May freeze in the winter if you use a water bleed. Hope this helps. Quote Link to comment Share on other sites More sharing options...
grant_hundley Posted November 13, 2008 Report Share Posted November 13, 2008 (edited) If one pad is rubbing you need to put more tension on the vee arm on that side. They'll be a bolt that you screw in putting more tension on the arm. to set it up you just have to put the pad on the rim straightish, pull the lever and tighten the pad up. Also, you have to try and get the arms to be as parallel as possible to the rim (when the brake is pulled) to make it feel and work best. Edited November 13, 2008 by Bob Fossil Quote Link to comment Share on other sites More sharing options...
craigjames Posted November 13, 2008 Report Share Posted November 13, 2008 blahif the issue was the setup of the brake then thats you at fault, because i imagine 99% of riders that can set up a vee correctly would find that setup works fine.personally i founda maggy just as fiddly to set up if you wanted it perfect. Quote Link to comment Share on other sites More sharing options...
I am ze best Posted November 13, 2008 Report Share Posted November 13, 2008 As long as the Magura works and doesn't need bleeding it'sgoing to be a lot better than the v-brake. The Magura would be mychoice and any good rider will either have discs or Maguras. Theywon't have v-brakes unless they have to.Hope this helps. Quote Link to comment Share on other sites More sharing options...
Smoby Posted November 13, 2008 Report Share Posted November 13, 2008 Hey, go for the Magura, it's the best option I'm my opinion, but i guess its up to you. . Quote Link to comment Share on other sites More sharing options...
forteh Posted November 13, 2008 Report Share Posted November 13, 2008 Use a vee on the front and its awesome, super light grind and coustsinks - stupid hold and more than enough bite On my old forks its was very, very noisy and bite was spectacular; since putting pace reverse mount forks on the bite has reduced alittle (but with way more modulation ) and the honk has reduced to a woosh which is far nicer The front vee is about 100g lighter than a maggie setup which was my reasoning to use it. Quote Link to comment Share on other sites More sharing options...
eskimo Posted November 13, 2008 Report Share Posted November 13, 2008 I wasn't going to go on about all the advantages before but there are a few not covered.Vees can get in the way more. They like to shake too when jumping about when not used with much calliper tension. Which both cause the brake to grab the rim. And because of the movement in them, i've broken two calipers. One being a Deore and the other a XTR. I also remember before Avid brakes were good i always seemed to have problems with my Arch Rivals.Vee brake levers are cheaper and stronger.The Vee can be setup for barspins/ whips if that's what your into. Using a longer Linear cable.Wet weather pads for Vee brakes only seem to be Coust and Rock Blue currently. (yes Rock Blues work in the rain/wet)Vee brakes are totally interchangeable with other brands, eg, Shimano Lever, Avid Caliper, Odyssey Cable.The Vee brake generally needs more specialist tools for the job of setup/ maintenance. Cable cutters/ cable lube/ crimping tool/ allen keys. The Magura needs allen keys and knife. (as water bleeds don't need fluid or bleed syringe) Quote Link to comment Share on other sites More sharing options...
El Cristoff Posted November 13, 2008 Report Share Posted November 13, 2008 Between the two i would go vee.My vee was amazing, bit great both forwards and backwards, NEVER! slipped on a wall, the hold it had was insane.This was until Kennard snapped on of the spring adjusters, and then it all went to pot Don't be put off by people telling you there shit, cause they really arn't Quote Link to comment Share on other sites More sharing options...
Ali C Posted November 13, 2008 Report Share Posted November 13, 2008 As long as the Magura works and doesn't need bleeding it'sgoing to be a lot better than the v-brake. The Magura would be mychoice and any good rider will either have discs or Maguras. Theywon't have v-brakes unless they have to.Hope this helps.I chose to use vees when I won a french round of the world championships, came 3rd overall in the world that year in expert. I also ran vees out of choice when I came 4th in the Euopean Champs in master category as well as the time I came 8th in the final of a UCI World Cup round. Quote Link to comment Share on other sites More sharing options...
Jake Beach Posted November 13, 2008 Report Share Posted November 13, 2008 Maggie. Quote Link to comment Share on other sites More sharing options...
Jitters Posted November 13, 2008 Report Share Posted November 13, 2008 I've had very goo luck with vee's, but that's all I have ridden so far. Took the time to really learn how to set them up proper and I'm very pleased. Also, I don't have easy access to trials specific parts over here, so vee is the best option for cheap quick replacement at the local bike shop - not that this would be an issue for you.I would like to say that the Moe green pads work nicely with my set up/light grind, but they are crap once wet, so I may look into the rock Blue's as suggested as it's rainy here too. Quote Link to comment Share on other sites More sharing options...
Dan81 Posted November 13, 2008 Report Share Posted November 13, 2008 Have had several sets of vees over the years and (for trials) hated them all. One tiny bit of grit in the cable housing or any water and the whole feel of the brake is gone.One bike of mine has had the same old set of maggies for about 10 years - I havent needed to do anything apart from change the pads and they just keep working. A brilliant design. Quote Link to comment Share on other sites More sharing options...
jack w Posted November 14, 2008 Report Share Posted November 14, 2008 I,ve been runnin a vee and i think they hold alot better than magura's. Quote Link to comment Share on other sites More sharing options...
