Ollie Histon Posted November 9, 2008 Report Share Posted November 9, 2008 Orite, i got a magura with a dengura lever. tried bleeding it with water but after doing so pulling the lever does nothing. so should i be bleeding it with oil?also.. i bled it as you would a normal magura.. is there a different process with this lever? Quote Link to comment Share on other sites More sharing options...
Headley Posted November 9, 2008 Report Share Posted November 9, 2008 (edited) Orite, i got a magura with a dengura lever. tried bleeding it with water but after doing so pulling the lever does nothing. so should i be bleeding it with oil?also.. i bled it as you would a normal magura.. is there a different process with this lever?You could try a sink/bath bleed. You're almost garenteed to get it working unless you completley mess it up. Edited November 9, 2008 by Headley Quote Link to comment Share on other sites More sharing options...
El Cristoff Posted November 9, 2008 Report Share Posted November 9, 2008 Dengura levers are shite thats why, i had on running maggie slaves and it leaked like a sieve. Seriously, maggie levers work so much better. Quote Link to comment Share on other sites More sharing options...
Ollie Histon Posted November 9, 2008 Author Report Share Posted November 9, 2008 Dengura levers are shite thats why, i had on running maggie slaves and it leaked like a sieve. Seriously, maggie levers work so much better.it's not leaking though, its just not doing anything... Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted November 9, 2008 Report Share Posted November 9, 2008 it's not leaking though, its just not doing anything...Just take a minute and think about it logically. It's not leaking, so that's not the problem. You can move the lever so the piston isn't jammed. You pull the lever and nothing happens- there must be air in the system. And being as it's a Deng lever, you should really be bleeding it with oil. Quote Link to comment Share on other sites More sharing options...
Ollie Histon Posted November 9, 2008 Author Report Share Posted November 9, 2008 Just take a minute and think about it logically. It's not leaking, so that's not the problem. You can move the lever so the piston isn't jammed. You pull the lever and nothing happens- there must be air in the system. And being as it's a Deng lever, you should really be bleeding it with oil.yeah i think the problem is that im bleeding it with water. its just not working properly at all, will have a go at oil tomoro i reckon. Quote Link to comment Share on other sites More sharing options...
