Pad Wear Problems
Julius Czar
Hi
I got some heatsink cousts about a week ago and there wearing down quite quickly.
ive got a grind, but it isnt that heavy. Also my mate has got some and he has got a hevier grind than me, and his have barely worn down
has any one got any ideas as to why it is wearing so quickly?
thanks
Kiwi.
Do you mean wearing down unevenly, or wearing down all over? If it's uneven wear check that you've got the pads set up so they're hitting the rim square on. If they're set up at an angle (toed in for example) then the front's going to start wearing much quicker than the back.
Ah, that might be why i'll check. But ive got evo 2's and whenever you tighten them, the cylinders move at an angle, which makes it impossible to align them properly. Bit annoying.
Im getting a rulong soon so i wont have to live with it for that long till i can use 4 bolt mounts :)
