dan- Posted November 6, 2008 Report Share Posted November 6, 2008 for my maggie on the rear am thinking of running it on a grind or tar also what brake should i use on the front as i only have vee mounts and a non disk hub Quote Link to comment Share on other sites More sharing options...
mr ailsbury Posted November 6, 2008 Report Share Posted November 6, 2008 I've used Koxx Bloxx Brown pads for a couple of years now, IMO they're the best all round pads on the market.They last forever as well.http://www.tartybikes.co.uk/product.php?pr...p;category_id=4 Quote Link to comment Share on other sites More sharing options...
MiuSliS Posted November 6, 2008 Report Share Posted November 6, 2008 (edited) I'd say bloxx is a good choice. I'm using rocks though. Work good with grinded rim + tar gives extra grip. But somehow some people managed to brake the rocks. Don't know how that's possible. Hardcore riding maybe. http://www.tartybikes.co.uk/product.php?pr...p;category_id=4 Edited November 6, 2008 by MiuSliS Quote Link to comment Share on other sites More sharing options...
forteh Posted November 6, 2008 Report Share Posted November 6, 2008 also what brake should i use on the front as i only have vee mounts and a non disk hub I guess that would be a maggie or vee brake then Quote Link to comment Share on other sites More sharing options...
spaceman Posted November 6, 2008 Report Share Posted November 6, 2008 You don't really have to put tar on a grind.And my advice is to stay away from tar, they kinda get runny and messy when it's wet.As for the pads, I'll recommend Heatsink Quote Link to comment Share on other sites More sharing options...
pogo Posted November 6, 2008 Report Share Posted November 6, 2008 (edited) Love you dan, don't you need a wheel first?Plaz crv on the front, seem to work awesome on my mod.Onza have brought out some nifty little devices that you equip to v brakes to allow magura pads to be used. Search Onza on tarty Edited November 6, 2008 by pogo Quote Link to comment Share on other sites More sharing options...
Headley Posted November 6, 2008 Report Share Posted November 6, 2008 for my maggie on the rear am thinking of running it on a grind or tar also what brake should i use on the front as i only have vee mounts and a non disk hub As mentioned before go for something like koxx browns on a savage grind or reds on a medium grind. As for the front brake go for an avid SD7. They're amazing, i'm currently running one with plazmatic pads on a completly smooth rim and it's working fantastic. Quote Link to comment Share on other sites More sharing options...
Nick Manning Posted November 6, 2008 Report Share Posted November 6, 2008 Phat pads on CNC backings, they are amazing on street.I guess it depends on what your riding. Quote Link to comment Share on other sites More sharing options...
JonCongreve Posted November 6, 2008 Report Share Posted November 6, 2008 Try the new Try-All Croco pads? Alot of people on here seem to rate them although they are fairly new. I'm gonna get myself a set when my plazzies run out. Quote Link to comment Share on other sites More sharing options...
Crazyman Posted November 6, 2008 Report Share Posted November 6, 2008 For smooth rims is best neon 2008 pads.In wet neon pads work better compare with echo/zoopads. It also pretty good on very light grind. For grind and good work in wet i'd recommend heatsink coust pads. Imo they are works better then koxx bloxx brown in wet.If you have only vee mounts on front use vee-brake)) I'd recommend avid sd7 with avid lever+teflon cable and handmade or heatsink pads Good luck! Quote Link to comment Share on other sites More sharing options...
polish pete Posted November 6, 2008 Report Share Posted November 6, 2008 Personaly I think that the plaz CRM's are really good! Sharp grind will make them have a lot of bite and they will lock. The best brake pads I'v ever had! Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted November 6, 2008 Report Share Posted November 6, 2008 Personaly I think that the plaz CRM's are really good! Sharp grind will make them have a lot of bite and they will lock. The best brake pads I'v ever had! But they refuse to work when it's even slightly damp. Quote Link to comment Share on other sites More sharing options...
lil pads Posted November 6, 2008 Report Share Posted November 6, 2008 Hi I run a grind on the back asnd have adamant rock pads I have had them for 1 year and they have hardly worn The work well on the back Why don't you get some V ee brake adaptors and a magura hs33http://www.tartybikes.co.uk/product.php?pr...p;category_id=5http://www.tartybikes.co.uk/product.php?pr...p;category_id=5http://www.tartybikes.co.uk/product.php?pr...;category_id=72Heres some links hope I have helpedJohn Quote Link to comment Share on other sites More sharing options...
D A N N Y Posted November 7, 2008 Report Share Posted November 7, 2008 Yet again another pointless topic "What Pads Should I Get", Are you dumb or something do you not have a brain you should be able to make your own mind up these kind of pointless topics really p*ss me off, pointless if you look on tarty bikes it tells you whether the pads work good on a Light grind dry weather with tar etc.Danny Quote Link to comment Share on other sites More sharing options...
