stoozie Posted November 3, 2008 Report Share Posted November 3, 2008 Hi.I've just purchased a Onza Zoot 24", and I really would like to know how to make it single speed.Right now its got 8 gears.I'd really like to know- What tools I would need- What new products I would need- And how to do itthanks in advance. Quote Link to comment Share on other sites More sharing options...
Adam Griffiths Posted November 3, 2008 Report Share Posted November 3, 2008 you will need a sproket and chain tensioner for starts Quote Link to comment Share on other sites More sharing options...
Jack spalding Posted November 3, 2008 Report Share Posted November 3, 2008 For a singlespeed, You'll need to remove the rear derailleur which you'll need an allen key for. You may also need a new singlespeed chain (kmc are pretty handy), so you'll need a chain delinker to remove spare links. Then with the derailleur out the way you'll need to remove the rear wheel and remove the cassette using a cassette tool. Take one of the small cogs from the cassette depending on what ratio you'll need depending on the amount of teeth on the front chain ring. Then using cassette spacers you can securely fix the single cog in place. i.e [ = spacer[[*[[ * = cogThen with the cog securely fixed and the cassette ring screwed back on that parts sorted. Then you'll need a singlespeed roller, which goes in place of where the derailleur was. Get the chain as tight as possible without having it too tight (so the train runs smoothly), then put it through the roller and tighten it up.TOOLS:chain delinkercassette toolallen keyssomething to remove the wheel bolts with - allen/ spanners. PARTS:Singlespeed chainrollercassette spacerssingle cog (which can be nabbed from original cassette)Hope that is of some help. Quite hard to explain without showing! Quote Link to comment Share on other sites More sharing options...
stoozie Posted November 3, 2008 Author Report Share Posted November 3, 2008 Thanks I'll order the parts I need tomorrow, and then get onto it when they arrive Thanks for your help. Quote Link to comment Share on other sites More sharing options...
