Magura Hs33
neotropolis
I dont see how I could be doing it wrong, could there be a leak do u think?
If there was a leak you would be able to see water/oli coming out, have alook at all the ends to make sure there isn't, you could be bleeding it wrong, if you havn't got all the air out of the system that can cause the brake to have no power.
How can i ensure that i get all the air out?
There may still b air in the hosing, or it may need to be cleaned, and when you are bleeding the brake make sure you hav the hole blocked when you are pumping the liquid through the whose, this could be one reason why it has no pressure in the break.
Adam(Y)
Mate, you're obviously doing it wrong somewhere along the line. Otherwise it would be working. Sometimes it takes more than 1 syringe load.
Adam(Y)
Cover which hole?
I have already put 2 syringe loads through. Do you think it might need more than that?
Yeah i would like to know that aswell.
As would I.
Even after bleeding god knows how many b'jillions of Maguras in the past 13 years, it still does not come out perfect every time.
Here is a hint (not sure it is on the Magura manual or not). If you bled it correctly, more than likely most (if not all) the air causing the problem, is in the lever (master cylinder). To fix this without rebleeding for the 10th time:
1. Stand bike up. Flick lever a bunch of times (moves air further toward bleed screw).
2. Lay bike down so that brake in questions lever is closest to the ground (lever blade pointing toward ground, bleed bolt pointing toward sky).
3. Undo bleed bolt and take it out. If you look down, more than likely the oil it not right up to the top. Pull the lever blade (SLOWLY! lest you want an eyeful of Magura oil) until the oil is forced to the top of the hole.
4. Slowly release lever and drip oil in hole (keeping oil level with top). When lever is all the way released (and oil filling hole all the way to top).
5. Replace bleed bolt
6. Go ride.
On really bad days it can take a couple times of this (remember to flick lever in between). I can tell you it is a hell of allot faster than complete re-bleed.
6. Go ride.
Ill definitely try this if it means not having to re-bleed the brakes.
