Maggie Cnc Lever Blades
They're expensive which is probably why no one has replied, as they don't have them. But they're produced in Germany...
I had the old long lever blades and they're sweet. My friend has the new ones, and they certainly do give more power. As for stiffness they're pretty good, but maybe the CNC'd ones are stiffer?
yeah they look better, i used my friends one dunno if it makes much difference, i guess it depends how much you ride to justify £20 ish for just for a lever blade for me personally its not worth it as i don't ride that much.
but thats totally up too you.
the current maggie blade ive got is slightly thinner because i bent it in a vice and i ground prt of it out but it still makes my finger blister like f**k. ive got a hope mono trial on the front and the design of the lever has never made my right finger blister at all.
so i was just asking if the cnc maggie blade would do the same ans the lever blade you get with a full maggie brake
yep it would...mines lush
its the original magura cnc'd one ( the aftermarket one ) and its brilliant...not noticably stiffer , but a little bit lighter ?
