Lewis-Trials Posted October 30, 2008 Report Share Posted October 30, 2008 Hi everyone i recently bought a Brand new Zona Zip and i have been riding today around my area and different trials spots around Nottingham. while i was on the bike standing up there was rocking movement in the forks Forward and Backward. I dont know if its okay just needs some movement in the forks or headset. Just wondered whats wrong and it okay to ride tommorow. Quote Link to comment Share on other sites More sharing options...
I am ze best Posted October 30, 2008 Report Share Posted October 30, 2008 Maybe your stem or something like that is lose but it will be ok toride for a few days and if it gets worse take it to a bike shop and they will hopefully help you out. Quote Link to comment Share on other sites More sharing options...
Adam Fisher Posted October 30, 2008 Report Share Posted October 30, 2008 (edited) Well if its brand new it could be that your top cap is loose which is a easy fix ,or your headsetcould be bedding in alittle so you tighten your stem upalittle also you do this with the same problem above.Or just take it to your local bike shop and see what they say.But i wouldnt ride it until its sorted. Edited October 30, 2008 by trials adam Quote Link to comment Share on other sites More sharing options...
TJ. Posted October 30, 2008 Report Share Posted October 30, 2008 loosen the two stem bolts that clamp to the steerer tube then tighten the headset screw up in the top then do the stem bolts back up again.any problems contact me tj Quote Link to comment Share on other sites More sharing options...
Lewis-Trials Posted October 30, 2008 Author Report Share Posted October 30, 2008 Okay thanks ill do that tommorow step by step so i get it right Thanks alot any more advice please just message me Quote Link to comment Share on other sites More sharing options...
*Koxx hydroxx 2 Jack * Posted October 30, 2008 Report Share Posted October 30, 2008 Hi mate,I had the same problem with my t pro ,in my case the spacers had overlapped the stem ,so whenever i tightened up my headset it was still loose after about 10 minutes of riding .Have a look at your spacers if they are deformed at the ends buy new good quality spacers and that should fix it .Hope i have helped .Jack. Quote Link to comment Share on other sites More sharing options...
Lewis-Trials Posted October 30, 2008 Author Report Share Posted October 30, 2008 Adamant A3 said: Hi mate,I had the same problem with my t pro ,in my case the spacers had overlapped the stem ,so whenever i tightened up my headset it was still loose after about 10 minutes of riding .Have a look at your spacers if they are deformed at the ends buy new good quality spacers and that should fix it .Hope i have helped .Jack.Hey Adamant again erm right yeah ive got a problem i just bought this bike from SuperCycles yesterday so i think it must just be the top bolt come loose or the side stem what do you think. I dont have any more money to spend on the bike till i get my debt paided off at the moment Quote Link to comment Share on other sites More sharing options...
Jitters Posted October 30, 2008 Report Share Posted October 30, 2008 Hey, just like they mentioned above about loosening the 2 stem bolts and tightening the top cap a bit, but don't overtighten it. Make the top cap bolt a bit snug and maybe another quarter turn, so you don't go wrenching the star nut out of place. Good luck! Quote Link to comment Share on other sites More sharing options...
Lewis-Trials Posted October 30, 2008 Author Report Share Posted October 30, 2008 Okay will do tommorow in the light too cold now to do anything. Thanks tappets if got the name wrong Sorry. Quote Link to comment Share on other sites More sharing options...
*Koxx hydroxx 2 Jack * Posted October 30, 2008 Report Share Posted October 30, 2008 (edited) Tappets said: Hey, just like they mentioned above about loosening the 2 stem bolts and tightening the top cap a bit, but don't over tighten it. Make the top cap bolt a bit snug and maybe another quarter turn, so you don't go wrenching the star nut out of place. Good luck!Sounds good i forgot its quite new so your probably right ,it wouldn't have had time for the spacer to overlap the stem unless super cycles over tightened it (which is unlikely.) so yes just loosen the 2 bolts on the stem ,tighten up the top bolt ,but i would say a full turn to be safe and tighten up the stem , but be careful the thread on the stem rips out very easy. Edited October 30, 2008 by Adamant A3 Quote Link to comment Share on other sites More sharing options...
Ben H! Posted October 30, 2008 Report Share Posted October 30, 2008 Had this problem with my old t-mag, i just replaced the headset & it was fine after that Quote Link to comment Share on other sites More sharing options...
Lewis-Trials Posted October 30, 2008 Author Report Share Posted October 30, 2008 Ben H! said: Had this problem with my old t-mag, i just replaced the headset & it was fine after that Okay thanks ben for the information yeah when i get the money i will replace the standard parts but will it be fine for a few weeks/months Quote Link to comment Share on other sites More sharing options...
RETROLEO Posted October 30, 2008 Report Share Posted October 30, 2008 the same thing hapend to my mates onza just after he got it all he did was tighten the allan key bolts and it should stop, if it dose not work then i dont know. hope i helped and hope it fixes soon. Quote Link to comment Share on other sites More sharing options...
Lewis-Trials Posted October 30, 2008 Author Report Share Posted October 30, 2008 RETROLEO said: the same thing hapend to my mates onza just after he got it all he did was tighten the allan key bolts and it should stop, if it dose not work then i dont know. hope i helped and hope it fixes soon. Okay thanks RETROLEO i will be tightening everything up tommorow. Quote Link to comment Share on other sites More sharing options...
adam 94 Posted October 31, 2008 Report Share Posted October 31, 2008 Its probably just your headset. Loosen the stem and take your headset cap off and then pull up your forks and tighten up the headset. then the stem.Its probably just your headset. Loosen the stem and take your headset cap off and then pull up your forks and tighten up the headset. then the stem. Quote Link to comment Share on other sites More sharing options...
A.Baxter Posted November 2, 2008 Report Share Posted November 2, 2008 My headset was really loose for ages, if you dont do too much front wheel moves it will be fine for a while. i eventually baught a new star nut and top cap and bolt and its fine now. You probably only need to tighten it though. Just loosen the stem and tighten the bolt in the top cap Adam Quote Link to comment Share on other sites More sharing options...
