19" Rim Build
Jack Chinnery
Right before you say "look at the wiki" lol
i need help im about to order a echo rim off tarty but i currently run a onza 20" wat do i do? i already have the spokes and hub ?? hmmm
do i need to order some new spokes specialy for 19"
i need info lol
cheers jack
Edited by Onza t-vee rider jack :)
  Trials Punk said:
Have you looked in the FAQ?
How To Build A Wheel
How To Calculate Spoke Sizes
Spoke Length Calculator
If the rim is smaller, your going to need shorter spokes. Either cut your current spokes down to size and re-thread them or buy new ones.
cheers mate thansk for the help
  _CRED_ said:
I don't think you will be able to run a 19" rim if you were running a 20" before if your running a rim brake because it won't set up properly?
except maybe if you can get adapters?
Only half inch difference at the point where the brakes hit the rim. Should be able to take it up with adjustment.
  • 3 weeks later...
They fall under the same catagory on the website, yes, but they come in many different lengths depending on the hub and rim ERD.
Obviously the spokes from your 20" wheel would be too long for a 19" rim, as the rim is smaller. Ring Tartybikes, tell them your hub and rim, and they'll sort the length out for you!
  Onza t-vee rider jack :) said:
Spokes aren't a one-size-fits-all item. Please don't try and call me out, I'm not a retard.
As Dan said, if you want to know the right length of spokes for your wheel build, either use a spoke calculator (If you know the hubs flange diameters and center to flange distances, and the rims ERD) or ring up Tarty and tell them what rim/hub you want to use. Chances are they'll be somewhere between 182 and 188 anyway for a standard 3x rear wheel build.
EDIT: Are you going to build the wheel yourself?
Edited by Mark King
