Petr Stephens Posted October 18, 2008 Report Share Posted October 18, 2008 I Just Got An Onza Bird 2009 Which Has Disc Brake Mounts And Magura Mounts, It Comes With A V-Brake On The Back And A Disc Brake On The Front, What I Need To Know Is Should I Get A Disk Break On The Back Or A Magura Break On The Back? And Should I Swap The Front Disc Brake For A Magura? Please Wb Somebody. Quote Link to comment Share on other sites More sharing options...
G-baby158 Posted October 18, 2008 Report Share Posted October 18, 2008 (edited) Its all up to what you like better mate, the cheaper one would be a maggie because i think you will need a new back up to got disc.Your not allowed pics in sigs. Edited October 18, 2008 by G-baby158 Quote Link to comment Share on other sites More sharing options...
Petr Stephens Posted October 18, 2008 Author Report Share Posted October 18, 2008 Its all up to what you like better mate, the cheaper one would be a maggie because i think you will need a new back up to got disc.Your not allowed pics in sigs.Thanks for the info and i din't know that (I just signed up to trials forum bout 1hr ago) il take it out now. Quote Link to comment Share on other sites More sharing options...
Danny Metcalfe Posted October 19, 2008 Report Share Posted October 19, 2008 i got the same bikegood choice i just replaced the rear brake with a magura hs11 and looking to replace the front disc i find it sometimes comes loose after alot of use although the fact im abit chubby might have something to do with it ...but also i slipped on a rock n if bent the disc and caused some damage which is very easy to do so i would suggest to switch Quote Link to comment Share on other sites More sharing options...
Petr Stephens Posted October 19, 2008 Author Report Share Posted October 19, 2008 i got the same bikegood choice i just replaced the rear brake with a magura hs11 and looking to replace the front disc i find it sometimes comes loose after alot of use although the fact im abit chubby might have something to do with it ...but also i slipped on a rock n if bent the disc and caused some damage which is very easy to do so i would suggest to switchThanks For The Info, Do You Have Any Suggestions On What Disk Break I Should Get? Quote Link to comment Share on other sites More sharing options...
Ryan-Trials Posted October 19, 2008 Report Share Posted October 19, 2008 Thanks For The Info, Do You Have Any Suggestions On What Disk Break I Should Get?Avid bb7 185 or 203 all the way amazing brakes Quote Link to comment Share on other sites More sharing options...
eskimo Posted October 19, 2008 Report Share Posted October 19, 2008 It sounds like (from reading the other post to) that your trying to upgrade the bike all over. I rekcon you should just buy another full build that's on offer. Quote Link to comment Share on other sites More sharing options...
