Hey!
hoernig
hi find a good wall or some pallets and stack them up so you can practice.
wheelie in to it then so you can get your front wheel on then hold front brake lean forward and feather front brake so you get on.
Edited by lil pads
I'll try that a bit later when its stopped raining!
I have a bit of a problem with the front brake, there was a hole in the crossover pipe so i took it off,
but now i cant get the new pipe over the shroud nut :( Any ideas for that?
Thankyouu,
Hoernig
Thankyouu,
Hoernig
Heat it up, that way the pipe will expand allowing you to put the pipe on easier :)
