How Many Teeth!
Dan81
... and sorry.
So you should be.
Now back to my questions...
Debating just getting a more moden set up - b/b (maybe isis I dunno whats best?), crank and screw on chainring. Seems like these bolt on ones are becoming/have become outdated?
Are these http://www.selectbikes.com/index.php?act=v...mp;productId=35 Echo cranks any good? then theres the question of what size crank (more confusion).
Edited by Dan81
if it makes it easier to find a good gear....
divide the teeth on the front cog by the ones on back
this gives you a rough idea how hard the gear is
the lower the number, the easier it will be
ill do some for you...
most widely used set ups at the moment
18/15 = 1.2
18/16 = 1.125
others that you can use at the moment...
22/18 = 1.222
22/19 = 1.157
22/20 = 1.1
22/21 = 1.047
20/17 = 1.176
20/18 = 1.111
20/19 = 1.052
  • Like 1
once you have the ratio of you gear (what i posted up before) times that by how many engagements you have.
now divide 360 by that number you just got (gives how many degrees till it engages)
so for me it would be... 22/18 = 1.222 * 72 = 88. 360/88 = 4.090.
so i get an engagement every 4 degrees.
now double your crank length and times it by 3.14
now divide it by 360 and times by the number of degrees
so for me it would be 350*3.14 = 1099/360 = 3.052 * 4.090 = 12.482
this means you have to move the crank 12.482mm to get an engagement (22-18 gearing using a chris king)
was that what you were after?
For someone like me of the "**** it, I can probably make that." mentality, its probably overkill but yep, at least I can work it out before forking out. Appreciate that - thanks.
Any thoughts on the echo cranks anyone? or just put the £ towards middleburns (is 16T front going to be the new standard?)
'burns are stronger, stiffer and lighter (i think)
but echo's are cheap.....
i'd go with the burns personally, i've owned both and my echo's snapped.
the 16t bash's are alright, chains are more prone to snapping and when the sprocket wears out, you have to pay a lot to get it replaced.
thought about 'burns with the heatsink bash? solid bash's with replacement sprockets.
