jack0174 Posted October 12, 2008 Report Share Posted October 12, 2008 hello.i wanted to strip my frame so it was silver, it only has white gloss spray paint on it.would i have to sand the frame, or could i use white spirits or something similar?Thanks Quote Link to comment Share on other sites More sharing options...
bollo you ball-bag Posted October 12, 2008 Report Share Posted October 12, 2008 nitromorse.buy it and do as instructed on the back of the tin. sorted. Quote Link to comment Share on other sites More sharing options...
adam 94 Posted October 13, 2008 Report Share Posted October 13, 2008 I sanded mine down, but i didn't respray it! It should be ok to respray it after you've sanded it down. Quote Link to comment Share on other sites More sharing options...
joedaho Posted October 13, 2008 Report Share Posted October 13, 2008 (edited) What he said ^^^ (EDIT - lozz that is) . I've got a mate who did it on his DH bike and it looked phit. Needing buffing a lot to keep it looking nice though, hence I was too lazy to do it to mine when I had it apart last. Edited October 13, 2008 by joedaho Quote Link to comment Share on other sites More sharing options...
Jake Beach Posted October 14, 2008 Report Share Posted October 14, 2008 It should be ok if you sand it. Quote Link to comment Share on other sites More sharing options...
Has anyone seen my shoe? Posted October 14, 2008 Report Share Posted October 14, 2008 Sanding is one way, Nitromorse is nasty stuff, gets the job done but you want to be careful with it.It really depends on the effect you want after you strip is. If you just want the base metal then mitromorse might be best option. Don't forget you might want to cover the frame in a clear laquer once you are done to save it from the elements Quote Link to comment Share on other sites More sharing options...
Muel Posted October 14, 2008 Report Share Posted October 14, 2008 If you want a raw shiny finish, then Nitromorse it and keep it polished up, if you want to re-paint it, see if you can get it shot blasted. Quote Link to comment Share on other sites More sharing options...
Mtchell Posted October 19, 2008 Report Share Posted October 19, 2008 (edited) Hi mate im a painter and dec/spray techicain ,i did mine recently this is what i did Stripped the frame down Sanded all the paint and any undercoat that is on the frame the sanded with a wet and dry pad not hard though this s jus to remove paint dust and sh!tnext get tack rag and wipe the whole frame ths will remove all the dirt and grime and what not next find a inclosed enviroment (so wind doesn't dust and so on,on to the wet paint) then get a oxidised metal primer and spray the frame leaving 15mins between each coat and giving a light sand with your wety and dry padwhen your have built up the primer leave the paint to cure for 24-48hrs next choose the paint you want and repeat the method again with the chosen paint, finally when you apply the last coat 15mins after apply the lacquer be careful as this makes the paint very soft and sticky apply up to 3 coats of lacquer and allow to cure for 7days before any out work is carried out (lacquer is for a shiny finish but also harden the paint agaist chips and scratchs)i know this sounds like a long process but believe me spraying takes time for the best finish, REMEMBER - Build the coats up dont try it on all at once otherwise this will cause runs, and the so called orange peel effect which is not a good look, hope this helps Edited October 19, 2008 by New2it Quote Link to comment Share on other sites More sharing options...
