monty boi Posted October 12, 2008 Report Share Posted October 12, 2008 A monty 221 ti 07 116 mm hub on a zhi zm2 frameplease tell me will it fit?thanks.Adam Quote Link to comment Share on other sites More sharing options...
JT! Posted October 12, 2008 Report Share Posted October 12, 2008 The older Monty hubs used to not fit mod frames well as they were shorter if i remember correctly. 113mm i think. But if that hub is 116mm you shouldn't have a problem. Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted October 12, 2008 Report Share Posted October 12, 2008 will be ok Quote Link to comment Share on other sites More sharing options...
Muel Posted October 12, 2008 Report Share Posted October 12, 2008 All Monty hubs are the same spacing, and are something like 110mm, they are designed to have the snail cams outside the frame aswell, so when you put the cams inside the disc mount is offset wrong, so you need to pack the caliper out by about 5mm.This is from personal experience, I've had one for 7 months on my Mod and it's been fine, you just need to use the snail cams inside the dropouts and 2mm of washers on the end of the axle.If you're thinking of buying one, I'd get something else, but if you've already got one it can be made to work easily enough. Quote Link to comment Share on other sites More sharing options...
