StevenJJ Posted October 9, 2008 Report Share Posted October 9, 2008 Hi people, was just wondering if you could tell me the differences between the pro2 trials hubs and the standard mtb ones. Would I be able to run a trials one with a nine speed cassette on a mtb frame? Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted October 9, 2008 Report Share Posted October 9, 2008 im not sure about the gear question, but the trials one has 48 engagement points and the std one only has 24 Quote Link to comment Share on other sites More sharing options...
craigjames Posted October 9, 2008 Report Share Posted October 9, 2008 the pro 2 trials has a 48 engagement point freewheel mechanism and has a 6speed cassette shell and therefore cant run a 9 speed cassette. a pro 2 is 24 engagement points and has a 9 speed cassette shell.feel free to correct me if im wrong. Quote Link to comment Share on other sites More sharing options...
N.Wood Posted October 9, 2008 Report Share Posted October 9, 2008 No, the trials one has a shorter freehub body only allowing a max of 6 speeds. Quote Link to comment Share on other sites More sharing options...
Matthew_Gibson Posted October 9, 2008 Report Share Posted October 9, 2008 and has less engagement points... as Ash saysMTBFeatures:• Bearing type:Cartridge (5 off)• Hub Body:2014 T6 aluminium• Colours:Silver,Black,Red,Blue,Gold,Purple,Gunmetal&Green.• Hole Drilling:28,32 &36• Cassette body:Aluminium• Ratchet type:3 pawl (24 engagement)• Rear 285gTrialsFeatures:• Weight: 295g• Bearing type: Cartridge (5 off)• Hub Body: 2014 T6 aluminium• Cassette body: Steel• Ratchet type: 4 pawl (48 engagement) Quote Link to comment Share on other sites More sharing options...
StevenJJ Posted October 9, 2008 Author Report Share Posted October 9, 2008 Ok so the only drawback would that I will have to run a 6 speed cassette yes? Quote Link to comment Share on other sites More sharing options...
grant_hundley Posted October 9, 2008 Report Share Posted October 9, 2008 and is an extra 10 grams heavier Quote Link to comment Share on other sites More sharing options...
StevenJJ Posted October 9, 2008 Author Report Share Posted October 9, 2008 and is an extra 10 grams heavier Does anyone no where i can get hold of a six speed cassette then? Sorry for the millions of questions people. :$ Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted October 9, 2008 Report Share Posted October 9, 2008 and is an extra 10 grams heavier omfg, gunna go file down my spokes to sort that out Quote Link to comment Share on other sites More sharing options...
grant_hundley Posted October 9, 2008 Report Share Posted October 9, 2008 any roadie cassette will be good, for trials you dont really need a wide spread of gears..a roadie cassette will have closer gears (if that makes sense) so each gear change isnt as big as on a normal cassette Quote Link to comment Share on other sites More sharing options...
Tomm Posted October 9, 2008 Report Share Posted October 9, 2008 Does anyone no where i can get hold of a six speed cassette then? Sorry for the millions of questions people. :$Just get a normal 8/9 speed cassette and lose the top 2-3 sprockets. The cheaper ones (Deore?) are better because the sprockets are easier to separate (you can drill out the bolts). The more expensive ones like XT have an aluminium carrier for the bigger sprockets and you can't take them apart. Quote Link to comment Share on other sites More sharing options...
StevenJJ Posted October 9, 2008 Author Report Share Posted October 9, 2008 Just gona look for a standard one seems like too much to change to get it running on my mtb Cheers for you're help guys Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted October 9, 2008 Report Share Posted October 9, 2008 not reallybuy a cassette, take it appart, spacer it out with 6 cogs, whats hard about that? Quote Link to comment Share on other sites More sharing options...
StevenJJ Posted October 9, 2008 Author Report Share Posted October 9, 2008 But surely then you'd have get a new deralieur and shifter cos mine are nine speed? Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted October 9, 2008 Report Share Posted October 9, 2008 nah, just dont use the top 3 gears... sorted Quote Link to comment Share on other sites More sharing options...
